1998 GT speedometer not working
Old 12-04-2015, 10:36 PM
stangcoupe1970
stangcoupe1970's Avatar
Default 1998 GT speedometer not working
I searched and couldnt find an answer to my specific problem.
The speedometer has been giving me issues for a while, it would read +/- what I was actually doing. A slap on top of the dash would correct it. The odometer recently went out, I replaced the gears and put the cluster back in. Now the trip and odometer work fine but the speedometer does not work at all.
Everything I found in my search said the speedometer and odometer were not working. I couldn't find speedometer not working but odometer working. My guess would be that I need a new speedometer motor but I can't find any online and I would like my mileage to be correct.
stangcoupe1970 is offline
Old 12-05-2015, 12:40 PM
Z28KLR
Z28KLR's Avatar
Going by the mention of how giving a smack to the dash would temporarily bring it back to life, it is most likely the stepper motor in the cluster.
What I would do just to be sure though is plug a tuner or other device that allows you to view pcm data into the OBD port, see what the pcm "thinks" vehicle speed is. If the pcm gives a "0 mph" or whatever reading then the issue would be the speed sensor on the trans; likewise if the pcm has a correct reading of speed then that confirms the issue is in the cluster.
Regarding the stepper motor, I am not sure where or if you can get a replacement. What I would try first is just buying a used cluster on Ebay or your local junkyard and either harvest the parts you need from it or swap out the entire cluster. As to how easy or difficult it is to take apart a cluster and remove parts, can't help ya there. Might be a Youtube vid on it somewhere that could give you a little direction though.
Z28KLR is offline
Old 12-05-2015, 01:18 PM
Urambo Tauro
Urambo Tauro's Avatar
Looks like Dorman offers remanufactured clusters.
You may also want to check out Accutach's website, which is chock full of useful information.
Urambo Tauro is offline
Old 12-06-2015, 09:58 AM
WJL
WJL's Avatar
+1 Z28KLR,
A 98 has a VSS Vehicle Speed Sensor which can be tested to confirm that's not the issue
WJL is offline
rooneyeb
Convertible Tech
07-09-2019 09:05 AM
rpmiracle
14
03-26-2016 02:33 AM
jesse1125
01-15-2016 10:56 AM
Devon123tay
12-11-2015 12:53 PM
Warner9195
12-05-2015 09:42 AM
Quick Reply: 1998 GT speedometer not working
