Newbie on modding, HELP AND TIPS NEEDED
Old 12-18-2015, 10:07 PM
iGotUrChica
iGotUrChica's Avatar
Default Newbie on modding, HELP AND TIPS NEEDED
Alright, so i'm very new to modding vehicles, i recently bought a 02 mustang GT. only maintenance I've done on it so far, is changing the spark plugs, and a couple oil changes. I've recently been planning my build, but before i install anything, i have a question about the way the engine idles. well first off, it sometimes revs itself, idk if that would be because of it "Warming up" or because at these times I've had the heat on? also, its not an attractive idle, is there any way i can improve it?
iGotUrChica is offline
Old 12-21-2015, 01:00 PM
Sandmanbjj
Sandmanbjj's Avatar
If you have not owned It from new, I would be sure the air filter is clean, the MAF is clean. Check your IAC to see if the Rev issue is related to that.
Sandmanbjj is offline
Old 12-21-2015, 09:10 PM
Z28KLR
Z28KLR's Avatar
If you have the hvac controls turned to either of the defroster settings then it runs the a/c compressor. The idle changes slightly as the compressor cycles on and off.
Z28KLR is offline
Old 12-22-2015, 01:54 PM
iGotUrChica
thanks very much appreciated
Sixer4Life
10-12-2015 04:26 AM
10-11-2015 08:59 PM
azoutdrman
10-10-2015 09:07 PM
gagemcc
10-07-2015 08:59 PM
Quick Reply: Newbie on modding, HELP AND TIPS NEEDED
