Tr3650 real seal leaking
01-10-2016, 05:40 PM
The rear seal was leaking on my transmission. I replace it with a new one. It just starting leaking again. I also just put a new yoke on the drive shaft. Is there anything else it could be or should I just try another seal?
01-15-2016, 06:59 PM
bad bearing in the tailshaft
01-16-2016, 01:48 PM
+1.Bad tail shaft bushing.
01-16-2016, 05:41 PM
No luck finding a place that sells a bushing. Is it even something that can be done in the garage or does it need to be pressed in?
01-17-2016, 03:41 PM
Not something that an auto parts place would carry.Have you tried Ford? or a local transmission shop, or did a search for Tremec parts?
01-17-2016, 04:50 PM
I had mine replaced last year by a transmission shop. They had to order in the bushing. From my understanding it is pressed in.
01-23-2016, 07:08 AM
Chupacabra
Pretty sure the tailshaft will needed to be separated from the transmission to replace.
Natasha Spizelli
02-21-2016 03:04 PM
JerkyChew
02-01-2016 01:23 PM
Evansmotorsports
01-16-2016 02:28 AM
Nando.
01-12-2016 01:08 AM
cominus
01-08-2016 02:47 PM
