2000 mustang rod bearing knock
Old 01-31-2016, 01:22 PM
Agentorange00
Agentorange00's Avatar
Default 2000 mustang rod bearing knock
Hey, I have a 2000 mustang and it has a small rod bearing knock, just wanted to know a good brand to replace them and where to buy them, thanks for your time
Agentorange00 is offline
Old 01-31-2016, 01:29 PM
Camster
Camster's Avatar
Welcome.
I don't think that there's an easy,quick,or inexpensive solution.
You should probably just buy a crankshaft kit,or have yours reworked by a machine shop.
Camster is offline
Old 01-31-2016, 07:25 PM
Agentorange00
Well where can I find a good crankshift rebuild kit? I don't wanna spend a million on rebuilding it, I would much rather buy the 04 cobra motor and tranny to swap if it gets too expensive
Old 02-01-2016, 07:26 AM
Camster
Camster's Avatar
I'm no even sure if reman crank exists in the market place.I could be dating myself..In any case,you have a big job to correct that issue,basically a rebuild.Once you remove the crank,you get into "might as wells",such as a new oil pump,new clutch,and if your knock is related to a piston pin?, A Cobra transplant gets involved too-as it uses a different driveshaft,etc.
In any case,I hope that another forum member can offer a more optimistic opinion.
Camster is offline
Old 02-01-2016, 07:29 AM
Agentorange00
I'm not 100% sure its a bearing, its hard to notice but if you feather the throttle right around 2500rpms when you let off the gas it makes a slight knock
Old 02-01-2016, 07:38 AM
Camster
Camster's Avatar
Sounds like a rod knock to me.Have a good mechanic give it as listen before you do anything.
Camster is offline
Old 02-01-2016, 07:54 AM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
COYOTE SWAP!!
fastbackford351 is offline
Old 02-01-2016, 07:55 AM
Agentorange00
I'd love too but I feel like that would be even more expensive
Old 02-01-2016, 10:13 AM
movielover40
movielover40's Avatar
You might be better off getting a junk yard motor.
movielover40 is offline
Old 02-01-2016, 06:35 PM
WJL
WJL's Avatar
all depends, is this your daily driver? If you have the time and can do the work yourself, I put rod bearings in mine.
I used clevite Tri Metal. Still driving it2000 mustang rod bearing knock-picture-044.jpg
however I have this sitting in the wings
Attachment 42217
WJL is offline
Maine-iac
03-11-2016 01:06 PM
zhendo
11-23-2015 10:33 PM
zhendo
V6 General Discussion
11-23-2015 09:58 AM
Toadster
11-23-2015 06:55 AM
LordRipberger
11-14-2015 04:59 PM
Quick Reply: 2000 mustang rod bearing knock
