2001 GT problems
2001 GT problems
Im going to make this short. A few months ago my air intake manifold cracked and started leaking coolant into the spark plugs. Ever since this my car has had a miss and I cannot seem to fix it. Is it the ECM messing with the injectors? Coolant leak? EGR? Things done:
Air intake manifold replaced
MAF, IAC and throttle body cleaned
Fuel filter changed.
Spark plugs and coils replaced(all 8)
First start in 5 weeks.Is this steam or white smoke from something bad like a head gasket?*
Sound byte for attention.
I have no cats also, true duels back to flowmasters. You could have had some water in the cylinders, but if it doesn't clear up shortly after a complete heat cycle then there is something else up.
2000mustanggt - YouTube
I know exactly what your problem is you bought the same gaskets I did when I made my mistake from a parts store it gives you the gaskets for the non-pi intake the PRI intake has little rubber reusable gaskets if you install the gaskets for the non-pii intake it will leak also you made sure that the two bolts on the underside of the intake we're tightened correct
Started it up today. Pretty sure it was just steam the other day. Makes sense since we had 3 feet of snow. Today it only had a little steam. Still has a miss of course. Its going to the garage on Tuesday.
johnnie_2207@yahoo.com
12-19-2015 03:10 AM
12-07-2015 06:55 AM
