Has anyone actually measured center line wheelbase? I know the 03's wheelbase is 101.3. Is it a big deal if they are not identical? If they are different, would the car pull to the side that is shorter. Mine is off 1/4" on the passenger side. Would love to have some extra input on this.
It needs to be square, you will have tracking problems like mentioned above, unusual tire wear, and bad steering input to name a few.
It's the GT I just finished. Car steers great. Brakes great. It has a slight pull to the right. Everything is new underneath. And everything lined up perfect. So I'm not really sure where to look.
loosen the k member and use a string and a plump bob to square it. The steering input wont be noticed at low to moderate speeds. The tire wear wont be huge but it mile cut the tire tread life down a little bit. Also, the car will track better the more square it is.
