well any idea?
Old 03-22-2016, 10:19 PM
justin0388
justin0388's Avatar
Default well any idea?
Why is the passenger side so far back. This used to be a V6 car. Cant find anything bent or out of the ordinary.
Attachment is driver side and passenger side. thanks
Attached Thumbnails well any idea?-20160214_123609.jpg   well any idea?-20160214_123558.jpg
justin0388 is offline
Old 03-23-2016, 06:54 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
could be that the K-member when it was swapped wasnt set in straight.. the holes are slotted. also, if the caster is out of whack that could also set the wheel back a tad. I want to say i've seen a ton of mustangs with a similar look...not as bad, but similar.
WhiteFoxGT is offline
Old 03-24-2016, 07:44 PM
ckelly78z
ckelly78z's Avatar
Check your toe in distance from the front of each tire. It should be about 1/4" closer than the back of each tire. It should actually be pigeon toed to a small degree 1/4".
ckelly78z is offline
Old 03-25-2016, 04:49 AM
dawson1112
dawson1112's Avatar
It looks like the K-member was not lined up, or the car was ditched and the control arm is bent. Possibly they didn't get the k-member bolts tight and it has slid back.
dawson1112 is offline
jordanair45
03-02-2016 09:36 AM
02-25-2016 10:30 AM
Rickf1985
02-23-2016 01:59 PM
Silverblade
01-25-2016 03:15 PM
AMAlexLazarus
01-20-2016 11:08 AM
Quick Reply: well any idea?
