Strange Knocking Noise Coming From Front End. HELP!!!
Old 03-24-2016, 02:23 PM
zhendo
zhendo's Avatar
Exclamation Strange Knocking Noise Coming From Front End. HELP!!!
What's up guys,
Here's a link to my last post, It will tell you everything you need to know about the mods I have on my 97.
https://mustangforums.com/forum/4-6l...ed-advice.html
Yesterday I was driving down the free way crusing about 75 MPH. Out of no where I noticed this strange noise which seems to be coming from the front drivers side wheel area. The noise is only noticeable above 65 mph. The best way I can describe the noise: It sounds as if the hood is latched but not fully secure and its bouncing up and down. Just a constant knock and it sounds as if it's happening and every full rotation of the tire. I got off the freeway and noticed the same sound when I came to a hard brake. I got to the place I was headed and looked under the car to see if I could find a brake pad hanging off. I noticed a piece of plastic from the wheel well that was torn so I kind of shimmied it to get it into a better position. I left my location and hopped back onto the free way and about 10 miles into the drive the slide started again.
All I know for sure:
Occurs after 65+
Noticed a bit more shaking of the steering wheel.
Seems to happen again at a hard brake.
Unsure of:
If it's just during acceleration or at both acceleration and coasting.
Where exactly it's coming from
I'm going to get under the car today to see if I can recreate the noise. If you guys have any ideas about what it could be or a specific place to start looking that would be great!
Thank you!!!
zhendo is offline
Old 03-25-2016, 11:21 AM
Camster
Camster's Avatar
Tire problem,balance problem,strut problem,hub bearing problem,sway bar bushing problem,broken motor mount.Take your pick,plus probably a few others.
Camster is offline
Thunderball
01-12-2018 07:56 PM
mohammadkhannj@gmail.com
02-21-2016 03:01 PM
Mmathews506
02-02-2016 05:13 PM
Mustanggirl719
01-13-2016 08:48 AM
fasterplease
01-12-2016 12:40 AM
Quick Reply: Strange Knocking Noise Coming From Front End. HELP!!!
