tube front end
Good luck finding a single turbo to make 900hp that your engine can spin before 5000rpm. Hope you know how to read turbo maps. His engine is alot different than your engine. You will not be able to run high compression due to the amount of boost you will have to run.
A pushrod engine built right can make 600hp NA easy. You will only need about 16lbs of boost to get it up to 1300.
I have the highest hp NA 2v that I know of at 500hp and it would not be great for boost, but the average hp level that will be good for boost is about 320hp. You will need about 25lbs of boost to get to 900hp. If you want this to be a strip street car and be able to run pump gas you will have to lower the compression ratio and run higher boost. Spraying meth will help also but then again if you want to run a certain class check the rules on intercoolers and meth together.
I was going to buy the trick flow 44cc to make my compression larger. right now I'm running 10.7-1 but that will change with 44cc trick flows before I get the turbo(s) in about a year from now.
and your right he runs 16lbs lol, also I do know the 10.7 is high for boost but I got a year or so before turbo, I wanted some gains now with my mmr stroker kit, many ways to alter my compression
Just saying, this is not a street car, although you have to admit, that is a really nice race car.
