A/C PARTS NEEDED
Old 06-20-2016, 12:30 PM
  #21
jwog666
jwog666's Avatar
Originally Posted by Z28KLR
Or if you want to open a fitting and blow the charge you can do that too, just be aware that it's not all that environmentally friendly and you definitely don't want to breathe it.
worst advise ever^^^
its a $10k reward for turning in anybody who discharges an ac system into the atmosphere. so if anybody who does would be so kind as to provide me with their contact info i could buy some more parts. but seriously, do it the legal and correct way, there is a reason they dont want this crap pumped into the atmosphere
jwog666 is offline
Old 06-20-2016, 01:11 PM
  #22
67STANGX2
67STANGX2's Avatar
I agree, I don't ever remember seeing that post. hopefully he was being sarcastic. any one with half a brain knows not to drain Freon in the atmosphere.
67STANGX2 is offline
Old 06-20-2016, 02:08 PM
  #23
Derf00
Gentleman's Relish
Derf00's Avatar
Originally Posted by 67STANGX2
UPDATE!!!! Job finished!! Took to shop this morning. First they vacuumed system for 45 min, then they did a leak test for 30 min. All was good , then he put the 134-A in. My compressor at first was cycling. The low pressure started at 40 then dropped to 20.. on the high side it would start at 215 and top off at 300. after about 30 minutes or so. the low side stabled at 30 and the high at 240. the compressor now does not cycle. the tech told me that the pag oil more than likely hadn't spread through the whole system yet. obviously it has now. And I saved over 700 dollars. Thanks all of you who helped!!!
Nice! glad to see it's all put back together and running well.
It generally does take a freshly revamped system a little while to stabilize as it equilibrates for the first time so your initial pressure fluctuations aren't a surprise. Do you know how much (lbs) of freon the shop put in? Just curious.
Derf00 is offline
Old 06-20-2016, 02:36 PM
  #24
67STANGX2
67STANGX2's Avatar
thanks for your encouraging words, 2.2 oz
Old 06-20-2016, 02:38 PM
  #25
67STANGX2
67STANGX2's Avatar
Smile
or should I say 2lbs and 2 oz,
Old 06-25-2016, 11:24 PM
  #26
DRAGUL
DRAGUL's Avatar
You can use compressed air or a liquid A/C system flush and compressed air (to dry it out). Your local Oreilly's or Napa will have something for that.
You never want to use compressed air on any system. Compressed air contains moisture. Use nitrogen only.
DRAGUL is offline
flash_xx
05-25-2016 10:27 AM
70XR7Tom
05-24-2016 07:30 AM
70XR7Tom
05-23-2016 09:49 AM
fastcobra96
05-20-2016 08:12 PM
Sgkukov
04-29-2016 09:50 AM
Quick Reply: A/C PARTS NEEDED
