Must shift to 2nd to get into drive
Old 06-09-2016, 09:49 AM
tom_emanski
tom_emanski's Avatar
Default Must shift to 2nd to get into drive
I have a 96 Mustang GT automatic 4.6l, periodically when I shift from PARK to Drive, nothing happens. I need to shift to 2nd to engage and then back to D (Drive) and everything works fine. It shift fine through all gears after that shift to 2nd and back to drive. No slipping or failure to up or down shift after that. It's just that sometimes it needs to go from park to 2nd to get the car in gear.
Suggestions?
Thanks,
Tom Emanski
tom_emanski is offline
Old 06-09-2016, 11:54 AM
jwog666
jwog666's Avatar
it seems that your shift linkage is sloppy and/or worn out. inspect it and replace anything that is suspect
jwog666 is offline
Old 06-11-2016, 12:47 PM
99GTvert
is my username.
99GTvert's Avatar
Moving to tech..
99GTvert is offline
Old 06-12-2016, 03:35 AM
09GT/CS
09GT/CS's Avatar
Yeah something has moved out of alignment. And it's not uncommon for the cables to stretch some. There should be a lock nut and adjuster at one end of the cable if the cable looks good/undamaged I would just adjust it till it works correctly.
09GT/CS is offline
maartyrr
03-16-2016 05:06 AM
Taylor D
03-06-2016 08:16 PM
Excel
03-31-2009 09:15 AM
ANTICIVIC
08-30-2007 01:01 PM
DirtyDee916
11-08-2003 05:57 PM
Quick Reply: Must shift to 2nd to get into drive
