Reuilding an 8.8 rear end
Old 06-12-2016, 07:20 PM
EpicMoses
EpicMoses's Avatar
Default Reuilding an 8.8 rear end
I have an 02 GT and I'm looking to rebuilt it with 3.73 or 4.10 gears. I can't use my housing due to the driver side axle tube being trashed, so can I use any ford 8.8 read end or does it have to be a mustang?
EpicMoses is offline
Old 06-12-2016, 09:08 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Needs to be from a 99-04 gt to be a direct replacement
94-98 gt/cobra will work, but be slightly shorter so the wheels will tuck, and a rear from a foxbody will be shorter and not have the brackets for disc brakes.
any v6 will have a 7.5 rear so dont buy one of them, it will drop in but not survive the power very long
WhiteFoxGT is offline
Old 06-13-2016, 05:11 AM
EpicMoses
EpicMoses's Avatar
Ok thanks for the info. Someone told me I could use any Ford 8.8 axle like the one from the F-150.
Old 06-13-2016, 01:05 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
you are referring to the housing itself correct? Not the actual differential?
housing is this WHOLE unit
differential would be just this
You can swap an 8.8 differential from any ford into basically any 8.8 housing. Only differences would be axle splines on the spider gears and whether or not it is a posi unit
you can not simply slap a housing from a f150 into a mustang
Old 06-13-2016, 01:22 PM
EpicMoses
EpicMoses's Avatar
Oh ok thanks for the clarification. I don't plan on changing the LSD or anything, just the gears.
Old 06-13-2016, 01:42 PM
Camster
Camster's Avatar
Just find another whole Mustang V8 unit.The whole thing as pictured above.It should be easy enough.
Camster is offline
Old 06-13-2016, 01:46 PM
EpicMoses
EpicMoses's Avatar
I was thinking that I could save money by using any empty housing and just swap the good parts from mine into it.
Old 06-13-2016, 01:59 PM
Camster
Camster's Avatar
Who sells an empty housing?? It will a complete unit from a junker.Beyond that,you'd be paying someone to strip it down,and adding to the expense,not cutting it.Not a horrible job to do a gear change,but if you have a damaged tube,I think that you have a lot of work ahead of you.
Camster is offline
Old 06-15-2016, 12:51 PM
chipss36
chipss36's Avatar
pyle brothers in bay town tx, trues em, welds em and builds great rear ends, they do all mine.
never has the wine.....
chipss36 is offline
xNightFirex
03-17-2016 05:49 AM
plane225
03-16-2016 10:14 PM
TuckJr67
03-15-2016 12:27 PM
TuckJr67
03-15-2016 12:25 PM
03-15-2016 11:32 AM
Quick Reply: Reuilding an 8.8 rear end
