1998 mustang gt clutch linkage noise
There is this allowing squeaking coming from the clutch linkage directly under drivers side feet. It stops when I press the clutch or grab this linkage.
Any ideas to make this stop is appreciated.
If it goes away when you are stepping on the clutch you should check out your throw out bearing. That's probably.it.
