Helicoil came loose in head!!! oh chit
Old 08-08-2016, 05:58 PM
SKOT
SKOT's Avatar
Default Helicoil came loose in head!!! oh chit
Hadda spark plug blow out a few years ago and repaired it with a helicoil kit..(I know I know....NOW...) ;( anyway I changed the plugs today and noticed that the plug with the insert was taking longer to seat and tighten up...so...I pulled the plug, looked in the hole and I can see the insert has threaded thru and is in danger of going into the cylinder if I try to go in again....SO...im not sure exactly what to do but cuss.... any ideas about how to get this thing out?...
Thanks
SKOT is offline
Old 08-08-2016, 06:43 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
hook pick and some prayers
WhiteFoxGT is offline
Old 08-08-2016, 09:50 PM
Z28KLR
Z28KLR's Avatar
If it falls down in the bore is there any chance, maybe with a little luck he'd be able to extract it with a telescoping magnet? Those thread inserts are made of steel, right?
Z28KLR is offline
Old 08-09-2016, 07:19 PM
Camster
Camster's Avatar
A little larger than the plug hole,so it can't be tugged by just a magnet through the hole.If it falls in,you almost lighted camera probe and spring loaded grabber to get it,possibly pulling on just an end so that it straightens out somewhat.Might help to have that cylinder's piston all the way up..
Camster is offline
Old 08-10-2016, 07:13 PM
SKOT
SKOT's Avatar
Default I Wonder
I thought about putting some threadlocker on the last 4 or so threads of a spark plug, letting it set up and try to back it out using pb blaster on the outer threads?...I prob need the "even GOD cant get it out" threadlocker for this tho...Thoughts?
Thanks Again
SKOT is offline
don-ohio
06-30-2016 04:37 AM
snowman_45
06-03-2016 04:54 PM
Caustin22
05-26-2016 11:30 AM
philipswanson
05-26-2016 10:35 AM
Stangbass
05-26-2016 06:28 AM
Quick Reply: Helicoil came loose in head!!! oh chit
