CLUTCH
Old 09-30-2016, 01:47 PM
67STANGX2
67STANGX2's Avatar
Default CLUTCH
JUS BOUGHT A WRECKED 02 W/ STICK. CANT GET IT TO CRANK. ALL LIGHTS LIGHT UP. IT HAS A AFTERMARKET ALARM, LOOKS LIKE I NEED TO RIP IT ALL OUT. DO YOU HAVE TO PRESS THE CLUTCH TO START?? THE FLOOR BOARD WAS KNOCKED IN A BIT, MAYBE IT WONT GO DOWN FAR ENOUGH.
67STANGX2 is offline
Old 09-30-2016, 04:16 PM
Soldier GT
Soldier GT's Avatar
Have you checked the starter?
Soldier GT is offline
Old 09-30-2016, 04:19 PM
67STANGX2
67STANGX2's Avatar
its not getting power to it, that's why I want to know if I have to press in the clutch. not sure if they came with a safety switch . if so, then the clutch may not be going down far enough due to the firewall dented in a bit
Old 09-30-2016, 04:21 PM
67STANGX2
67STANGX2's Avatar
I have never owned a mustang with stick. not sure of the starting procedure. it took me forever to figure how to take the key out. lol
Old 09-30-2016, 06:16 PM
Z28KLR
Z28KLR's Avatar
Yes there is a switch, located up at the top of the clutch pedal. Real bitch to get to and deal with, may consider spending two minutes removing the driver seat to make access a little easier (it will still suck though).
Z28KLR is offline
Old 09-30-2016, 07:29 PM
67STANGX2
67STANGX2's Avatar
thanks, looks like im going to try a pipe and sledge first to pop the floor board back and see what happens. I like the taking seat out idea
Old 10-01-2016, 07:50 AM
Camster
Camster's Avatar
You need to depress the clutch.For a car hit that hard,the inertia switch for the gas tank was probably tripped,so you must reset that too.
Camster is offline
Old 10-12-2016, 11:10 AM
67STANGX2
67STANGX2's Avatar
UPDATE.. I got this car started. The exhaust was banged up against the clutch cable on the Transmission.
demighost
02-07-2010 10:04 PM
1997Stang
SVT Forums
05-01-2009 07:46 AM
raubt
02-12-2008 08:40 PM
VanGTCS
10-17-2007 11:27 AM
earlymustang
02-21-2006 12:10 PM
Quick Reply: CLUTCH
