bounceing idle and stalling
#31
yup just make them aware of the current issue before hand ,the dyno shop will get it all working right for sure, they will beable to tell whats causeing your idle issue 4 sure
i just got thru installing another tps on the car rpms seem to not be hanging as bad as they were, havent moved car yet to know if bounce is gone yet,what made me think it just may be tps is the autozone description of what will happen if not replaced mainly the tranmission shifting will be off
#34
same her a auto, what it does is when it goes from 2nd to 3rd it will down shift back to 2nd while im on the gas just a little, but if im on the gas pretty hard doesnt seem to do it, i could see it doing that if i let off the gas but was on it steady
#37
Its official problem solved no more bounceing idle , does not bounce going in gear anymore smooth as a babys behind throttle postion sensor was the problem thx for eveyones input into this issue ! Hopefully this thread will help someone else
#39
just a little update after driveing the car the bounce and surgeing came bk, so put oem tb bk on the car and remove the bbk tb and well ! well! the bbk tb was the issue after all no surgeing like it was doing at all ,gotta set idle a tad higher on oem tb because of cams but seems to be good to go , was talking with a guy that had a 5.0 had same bbk tb and had same issue, so i figured what the hell tryed it and wala !
any of you useing ngk plugs and what type and are they worth a dam?
#40
it's my opinion that plugs are plugs, i know E3 and NGK all claim more/better spark even better fuel economy.
I think it's a bunch of BS really, if they in fact increased fuel economy or horsepower the car manufactures would be using them to improve their EPA ratings and reduce any fines they pay based on design requirements.
I have never put a set of plugs in my car and came back after a ride and said whoooooo, just saying Go Motor Craft
