Automatic Trans/ Driveline Clunk?
Alright guys, I went all the way back to page 12 and didn't find anything about this, so if it's been covered before I apologise.
I just bought a 2002 Automatic Gt with a shaker hood, ram air, 75mm throttle body, UDP's,superchip. 3.73 gears, X-pipe, and Magnaflow exhaust. I know I'm forgetting some stuff, but the upgrades are irrelivent... I just wanted to give you guys some background on the car.
Recently I noticed that when driving in overdrive and coasting at low speeds (usually 35 and below) it seems like the transmission doesn't know what gear it want's to be in and jerks a little bit. Sometimes it's so bad that it feels like the tail end of the tranny and the driveshaft is bouncing off the bottom of the car. What is the problem? Is this a common thing with GT's? Or should I book the first appointment to my local mechanic?
RE: Automatic Trans/ Driveline Clunk?
Transmission mount broken?
I know some people have complained when swapping to a shorter rear gear, their automatic tranny seemed to struggle with knowing when to shift... Maybe a handheld tuner would help by adjusting your shift points?
i got the same problem too-02 gt with the aode-no mods-but around 30-40-there's some crazy bucking that it does. It makes a crazy popping noise from the rear diff-at least thats where it sounds it like its coming from.
ORIGINAL: Dan04COBRA
ORIGINAL: SNORX302
That's exactly what I'm talking about, but to me it seems like it's right under my seat.
ORIGINAL: tripsevn7
i bet its the trans mount, i will almost guarantee it i broke mine twice in my 98 gt.
i hear a clicking from under the seat, but sometiems a popping further back. and i only feel it when the car is in drive and i have overdrive on-manually shifting-doesnt happen-but how good could that be on the tranny...
