oil
oil
My Gt is running on Fully Synthetic oil at the moment, does anyone see a problem with this, or should i change it to 5w 30w? and if i do need to change it, can i just drain and replace or do i have to run on semi then go to normal oil?[&:]
RE: oil
Theres no reason that you can't run fossil oil in your engine but why would you want to?Synthetic costs more but it's been proven to protect against wear better than fossil oil.Less friction allows better fuel economy and more power to the wheels also.
RE: oil
i know if you have been running natural oil and you want to switch to synthetic, you cant just get it changed and put synthetic in because the way each oil lubricates the seals is different so oil could leak into the combustion chamber
RE: oil
i run the same oil and oil filter everysingle time i change my oil
i use only Mobil1 fully senthetic motor oil, and a K&N oil filter
they do say however if you dont use the synthetic oil from the start then it wont do ne thing.. so always you it.. n if u hadnt it doesnt matter ne more
