how dose this look?
Old 11-25-2005, 02:30 PM
96mustanggt46
96mustanggt46's Avatar
Default RE: how dose this look?
I have the same hood here are some pics to help you decide.
[IMG]local://upfiles/4124/02C4E83550744D77960794C75F737185.jpg[/IMG]
[IMG]local://upfiles/4124/33172FAA2DEC48E88A6B6695F940836D.jpg[/IMG]
[IMG]local://upfiles/4124/8895AE88396A48519F6CEE94494E9F3B.jpg[/IMG]
96mustanggt46 is offline
Old 11-25-2005, 02:42 PM
Dark_Horse
Dark_Horse's Avatar
Thanks man i think that hood look really good in black, is yours a 3" cowl? because the one im looking at says its a 3". what do you do about the cut out in the scoop in winter or when it rains? should i just bondo or fiber glass it closed?
Dark_Horse is offline
Old 11-26-2005, 02:04 AM
Dark_Horse
Dark_Horse's Avatar
should i worry about the whole in the scoop? like if it rains and water gets in?
Old 11-26-2005, 02:28 AM
meebix
meebix's Avatar
Nah man, dont worry.
Water gets in their all the time, plus they are suppose to be exposed so air can get in there.
Most people have them blocked off with some kind of netting or something, just so leafs and other big things cant get in. But still so air can pass thru. Others leave them wide open. Either way you'll be fine. Closing it off is stupid.
meebix is offline
Old 11-26-2005, 03:04 AM
Dark_Horse
Dark_Horse's Avatar
thats what i thought i just didn't want any water to ruin any thing
Old 11-26-2005, 07:22 AM
96mustanggt46
When i first got the hood it had no hole in the scoop, so I made one and put a screen from a used air filter that i painted silver and glued that behind the scoop. Now when it rains, I have cut out a plexy glass insert to fit the hole so no watter gets in there whene it rains or if i wash the car. I do this to keep the engine bay clean and i have had problems with getting the engine wet before. The plexyglass makes it look like there is nothing there.
Old 11-26-2005, 10:23 AM
nathansmith50
nathansmith50's Avatar
letting water get in there could end up causing problems in the long run.........at the very least your engine bay is going to get very dirty very fast.
nathansmith50 is offline
Old 11-26-2005, 04:06 PM
Hyper00
Hyper00's Avatar
I guess I'm opposite of the others. I love the scoop, but it would look better on a normal cowl. I think the "stepped" sides on that cowl makes the hood look too busy.
How's the 5.4 build coming anyway? I have been secretly taking notes because I was thinking of doing the same thing. MUAHAHAHA!
Hyper00 is offline
Old 11-26-2005, 07:22 PM
Aixtreme89
Aixtreme89's Avatar
You should be fine if water gets on your engine, you have water tight weather connectors. The only thing that will happen is your block will rust faster, along with some of your exposed ground connections. If you look under your intake manifold you have a perfect spot for an inch or so worth of water to puddle. I wouldnt worry about it in regular rain, but if you live in florida where there are down poors, you could get alot of water covering your motor real quick, exspecially if your doing 60 on the highway in a downpoor.
Aixtreme89 is offline
Old 11-26-2005, 07:38 PM
nathansmith50
i have an active hood scoop......and there is a drain so the water doesn't get into the intake. but it still drains into the engine bay.
Quick Reply: how dose this look?
