x-pipe or h
RE: x-pipe or h
sound wise, an X will give you a deeper and louder sound over stock, but the H or pro chamber will give you an even deeper and louder sound than an X. the H sounds a lot better at cruising speeds, but the H has nothing on the X at WOT. the X gives more HP, but the H gives more low end power. the difference is small, so just get the sound you want.
RE: x-pipe or h
I got the Off road x-pipe from my old h-pipe and i have flowmaster mufflers too, and i get more compliments and looks from more people, than my other buddy with the same car with an h-pipe, the x pipe is more louder, and with the flowmaster mufflers, the combination, will ber perfect
RE: x-pipe or h
ORIGINAL: nanaki
RE: x-pipe or h
I would go with an X-pipe if your have a flowmaster catback. The flowmasters are extremely deep as it is, and an H will only make it sound even more deeper. I hate flowmaster, and personally I think you are going to get an ever worse, annoying drone with an H-pipe.
However, with that being said, I think if you put an X on there, it might even out that typical flowmaster sound and end up sounding pretty nasty (as in good).
Good luck.
Good luck.
RE: x-pipe or h
ORIGINAL: meebix
Good luck.
Good luck.
