BBk valve covers
BBk valve covers
I installed a set of BBK polished aluminum valve covers on my 4.6 L Mustang and now the engine is using a quart of oil every 3000 miles.(it never used a drop before ) Now it is sucking it up through the PCV system. While this is not excessive, it bugs me that, because the BBK vavle covers do not have the proper baffling for the PCV valve like the factory covers, it now consumes oil. I have talked to BBK about it and they acknowledge that they have many complaints about it , but have no solution. They said they don't make a proper baffle for this valve cover. Does anyone know of a baffle sysytem I can insert ( I don't want to remove the BBK's to do it as it was a real pain to install them ) or any other solution that anyone has used successfully to fix this problem ?
RE: BBk valve covers
ORIGINAL: rex979
If I were in your shoes I would be taking the BBk covers off ASAP! Thats the fix to your porblems.
maybe if you put some thing in the line to kinda of keep it from going in the motor like some foam or something? just something to keep oil from being sucked in pretty much.
ORIGINAL: Dark_Horse
ya try and put fome in the line, but far enough up so it dosen't fall in the valve covers
yep! or if it was me, i would take off the valve covers and get some metal and bend it and cut it to fit it and then get it tack welded to the inner part of the valve cover like a splash guard type deal... i think that is all the valve covers are missing.
im in the same boat as you...
we have a few options which one is up to you:
tig weld a baffle
install breathers
oil/air seperators + return line or breathers (have to empty the collector)
shm seperators + return line or breathers (costly)
not to mention the location of the pcv valve is next to the master cylinder so if anything fits it will be tight.
i planned with the shop last week to do exactly as racer02 described, weld in a baffle
tig weld a baffle
install breathers
Steeda sells a kit that filters the oil out of the pcv and sends it back to the oiling system. That apperantly is a common problem with earlyer cobras, cause I think it mentions something about it in there add. Ok go to the steeda web site and find there oil seperator kit it is 69.95 and I think it will fix your problem. Sorry I dont know how to paste a link.
Agreed...Forget about looks if it's drinking oil like that!
-Bryan
-Bryan
ORIGINAL: 00GT00
ORIGINAL: rex979
I just run breathers.
what type of breathers to be specific? cobra?
are your vc baffled?
im just unsure if the breather alone would handle the blow by issues or if a seperator is needed to pull the oil from the pcv air before a breather vents the gases
sorry for all the questions...its just hard to find people who know what they are talking about
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
