Gear calculator question...
Old 12-01-2005, 05:32 PM
ibeeskeef
ibeeskeef's Avatar
Default Gear calculator question...
I was using the gear calculator on the sticky and it shows that 4:10's and 4:30's have the same RPM's in 5th gear at all the mph's I tried (75, 80, 85). Is this true? And if so, why don't people go with 4:30's every time instead of 4:10's since the RPM's are the same in 5th and the 4:30's pull harder?
ibeeskeef is offline
Old 12-01-2005, 05:40 PM
Tim37
Tim37's Avatar
Default RE: Gear calculator question...
245-45-17 tires
at 60mph with 4.10 gear rpm 2127.3
at 60mph with 4.30 gear rpm 2262.5
not much but there is a diffence.
Tim37 is offline
Old 12-01-2005, 05:43 PM
ibeeskeef
ibeeskeef's Avatar
i have 275/40/17's. Is that making the RPM's the same or what?
Old 12-01-2005, 06:03 PM
01yellowgt
01yellowgt's Avatar
no clue whats going on there then. 315/35/17 & 275/40/17 & 245/45/17 are all three the same diameter, so that shouldnt be an issue.
Cobra_Dan had 4.30's on his manual gt. No clue of anyone else.
01yellowgt is offline
Old 12-01-2005, 08:13 PM
jdaniel
I ♥ Acer
jdaniel's Avatar
There isnt much difference at all in the two. I had 4.10's in my car for the longest and was ready to go to 4.30's before I got rearended.
jdaniel is offline
Old 12-01-2005, 08:22 PM
Blue70
Blue70's Avatar
With 4.30's
Your tire's diameter is 25.681 inches
At 70 MPH in 5th gear, your motor is turning at 2,442.6 RPM
With 4.10's
At 70 MPH in 5th gear, your motor is turning at 2,329.0 RPM
I'm not sure if this is the program you used, but it's the one I use
Click HERE for calculator
Blue70 is offline
Old 12-02-2005, 01:30 PM
blackbetty01
blackbetty01's Avatar
ORIGINAL: jdaniel
How was someone able to catch up and rear end that thing!! J/K, I have been meaning to ask you about that picture, did you get it fixed or part it out and total it?
blackbetty01 is offline
Old 12-02-2005, 01:42 PM
jlauth
jlauth's Avatar
i was just on that calc how fast do you think that my car would be able to go cuz i was gonna see how that top speed would differ with 4.10 to my 3.73s. that was one of the two reasons that i went with the 3.73 the other was cuz of collegeand the dist from home.
jlauth is offline
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: Gear calculator question...
