Need Help intake manifold
Old 12-07-2005, 12:57 AM
Zero7
Zero7's Avatar
Default Need Help intake manifold
Been looking around and im having trouble finding and after market intake manifold any help would be great
Zero7 is offline
Old 12-07-2005, 01:04 AM
RedRoller
RedRoller's Avatar
Default RE: Need Help intake manifold
Hey man i live real close to you.What year is your car?
RedRoller is offline
Old 12-07-2005, 02:31 AM
demon_head
demon_head's Avatar
Assuming you have a 99+ GT, theres the Fox Lake P51 and the Bullit intake manifold. I think there's one more, but i cant remember what the name of it is.
demon_head is offline
Old 12-07-2005, 02:42 AM
JoeyD
JoeyD's Avatar
^Yes if you have a 99+(new edge) GT...
There is the...
Ford Bullitt intake manifold,
Reichard Racing's intake manifold,
Foxlake Power P-51 intake manifold,
X2C Motorsports intake manifold
^best of them are the Foxlake and the Ford Bullitt... IMO.
they show gains all across the board...
as where the others show gains in low rpms... but lose in the higher rpm HP levels.
so best is Ford or Foxlake... and I believe you can get the foxlake for less.
JoeyD is offline
Old 12-07-2005, 11:06 AM
DIVER8374
DIVER8374's Avatar
^^^^ I believe that you have it backwards JoeyD, The P-51 and Bullitt show gains across the RPM range but best gains are in themid-higher RPM's. The RR intake makes the most power in the higheer RPM range so you would have to build your motot to handle spinning the higher RPM's.
Hey code, Am I correct in this, that they show the best gains in the higher RPM's??? I believe I am if I am remembering correctly from all the research that I have done.
DIVER8374 is offline
Old 12-07-2005, 04:40 PM
codyss
codyss's Avatar
Also keep in mind why you are looking for a different intake when making your decisions.
The Bullitt intake would be the best if you are looking for a little HP and a better power curve.
codyss is offline
Old 12-09-2005, 02:51 AM
Zero7
Zero7's Avatar
mines an 03 sorry and thanks fo the help
Zero7 is offline
Old 12-09-2005, 03:02 AM
Zero7
Zero7's Avatar
red roller where u from
Zero7 is offline
mrtrodonet
09-19-2020 03:12 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
Dokilar
15
10-16-2015 08:13 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: Need Help intake manifold
