Those with OFF-ROAD MID-PIPES with MIL ELIMINATORS...come in
What brand of eliminators do you have?
I had Steeda MIL's, before installation my car ran 100% FINE.
After installation, I would be cruising at 30-40 MPH, push in the clutch and my RPMS wouldn't drop or they would spike. At idle, my car would jump from 700rpms to 1500 and stay that way for a minute or two, sometimes it would spike from idle and go to 3-4k!!!
Also, starting my car, once in a while it would idle high and then shut off.
After 4 months my CEL light came on, my idle returned to normal, my throttle quit hanging, pulled the code and determined my MIL Eliminator finally failed....
I've noticed a LOT of people having problems with their car right after installing MIL Eliminators, such as idling problems, misfires and such.
Lets elaborate...
Lets elaborate...
RE: Those with OFF-ROAD MID-PIPES with MIL ELIMINATORS...come in
i got mine form upr along with my mid pipes.
mine does the same thing but only after i put the flows on when i was running stock mufflers (i had them for about 4 months) it ran fine i think it is a lack of back preasure not the mils. the rear o2 sensors don'w effect how the car runs they are just there to keep a eye on the cats to make sure there working right.
Mine are crap also, i usually just leave the CEL on which kills my gas mileage, but recently I have been pulling the battery cable to reset the codes. My car runs perfect doesn’t misfire or have a bad idle, and the gas mileage improves greatly. Then the next thing i will look down at the speed o and the CEL will be staring me in the face. I can only get the light to shut off for about a week at the longest, but sometimes it will only stay off for a day or two. I know some one who has a friend on the inside of SCT said he could hook me up so I am gonna go that route.
I've also got the UPR MIL's and X-pipe. Never had any issues with anything. I've also got an IAC restrictor ( don't know how I drove without that thing)... The only problem I ever have with idling is I'm sure related to the IAC restrictor. If I turn the A/C on while idling it will sometimes die. I just always make sure when I turn on the A/C I blip the throttle or wait till I'm moving.
Interesting. I've seen a lot of people (here) install mid-pipes with MIL's and right after installing it they have all kinds of idling/misfiring issues.
All of my problems stopped as soon as my MIL's failed...
i got a UPR x-pipe and i bought a set of BBk MILs and havent had any problems either. Before i got them my check engine light came on and as soon as i installed them everythings been fine. when u install them make sure u disconnect ur battery and when done reconnect it. I also have flowmaster mufflers welded into my stock catback.
