screech on startup!!!
Old 12-16-2005, 02:52 AM
monkeydude3
monkeydude3's Avatar
Default RE: screech on startup!!!
are you serious??? As a matter of fact it does squeal like that. Usually in a few bursts... so would cleaning the moving parts on the starter buy me some time? I can't afford one right now, still turns the engine great. I figure I'd just clean where the starter gear slides for the time being and put some grease on it.
Thanks! Now I dont' have to worry too bad about something really gay going out.... from what you are saying it is my starter..
take care
George
monkeydude3 is offline
monkeydude3
now while I'm on that topic... how tough is that little guy to get out??
George
Old 12-16-2005, 01:15 PM
gt96stang
gt96stang's Avatar
Getting a starter out is a PITA. You have to be able to get that top bolt off. The other two are simple, just that top bolt.
gt96stang is offline
Old 12-16-2005, 01:30 PM
David_K
David_K's Avatar
ORIGINAL: monkeydude3
take care
George
i havent done anything about it. its very sparatic it doesnt happen every time i start the car
David_K is offline
Old 12-16-2005, 04:18 PM
monkeydude3
oh ok... what i've noticed is the cold weather brought it out. I figure I'll wait until it starts getting worse and then invest in a starter, considering the pita to get out.
Old 12-16-2005, 05:47 PM
monkeydude3
well I just put my stang up in the air here at work (had some free time) and It appears as if the H pipe has to come out to get the starter out??? If that's the case I am gonna live with the noise until I drop the tranny... I'm gonna pull the H pipe and trans out and the starter has to come out then.
so does the H pipe have to come out to get it out? I thought I could just yank the starter and clean it up and right now it look slike an hour project instead of 10 mins.
stupid noise.
Well i guess i'll rinse off the beast and get some of the salt off it. lol
George
Old 12-16-2005, 06:38 PM
TheBob98GT
TheBob98GT's Avatar
sounds like the clutch is bad or pilot bearing. when u start the car push in the clutch pedal and see if the screech goes away.
TheBob98GT is offline
Old 12-16-2005, 07:01 PM
Gregs68
Gregs68's Avatar
sounds like the starter to me
Gregs68 is offline
Old 12-16-2005, 07:53 PM
monkeydude3
well the thing is my clutch is down when i start it and i hold it down and it still does it. I think it is the starter sticking a bit.
george
Old 12-17-2005, 11:44 AM
04BlueGT
04BlueGT's Avatar
I'm not familiar with the starters on the 4.6, but I assume that they have selenoids like most. If that selenoid is going and finally gives out, you could end up with a running motor and an engaged starter. I would get it fixed asap before your flywheel gets potentially damaged.
Am I way off the mark here, guys?
04BlueGT is offline
Quick Reply: screech on startup!!!
