Shift Kit ?
Old 12-15-2005, 09:46 PM
redass02gt
EXTREME Moderation
redass02gt's Avatar
Default RE: Shift Kit ?
yes.
hell, if you ever do any work on your tranny, you might as well get the cooler put in. they should come with one from the factory. it'll help your tranny run a looooong time. heat is the #11 enemy of trannies.
redass02gt is offline
Old 12-15-2005, 10:11 PM
97stanger
97stanger's Avatar
okay...can someone give me a link with a good, yet cheap tranny cooler that would work with my 97 GT, AODE (if that matters)...thanks guys
97stanger is offline
Old 12-15-2005, 10:46 PM
97stanger
97stanger's Avatar
how does this tranny cooler look part # BMM-70264 at http://store.summitracing.com/ ... along with the transgo shift kit??
Old 12-15-2005, 11:38 PM
GrayGhost01GT
GrayGhost01GT's Avatar
When I get my 3:73 Gears and SCT Tunner will I need a Tranny Cooler? And what is the Stall? I feel stupid
GrayGhost01GT is offline
Old 12-16-2005, 10:00 AM
xx9gt6xx
xx9gt6xx's Avatar
4:10's, Shift Kit, Tune, DR's...You'll be sitting pretty
xx9gt6xx is offline
Old 12-16-2005, 11:29 AM
jlauth
jlauth's Avatar
stall is when an auto is able to rev higher before shifting to the next gear, high stall is great for the track, but bad for a daily driver. I dont know that much i have never needed to worry about that.
jlauth is offline
Old 12-16-2005, 11:42 AM
tripsevn7
Moderating with Angels
tripsevn7's Avatar
i ran a transgo shift kit in my 98 without a cooler and never had a problem by increasing line pressure via the kit my tranny never acted up in 96900 miles. 3.73 gears and a serious number of mods and i beat that car all the time with zero problems transgo shift kits are easy to install and i loved mine
tripsevn7 is offline
Old 12-16-2005, 11:47 AM
shane361
shane361's Avatar
I used a hot rod style tranny cooler it was rite about 100 bucks. I then needed some hose, hose clamps, little tool to cut metal tubing, and the little kit that flairs out tubing so the hose will go over and seal rite. I bought all this stuff for under 50 bucks at a hardware store. The major problems with trannys is over heating so even a stock auto would last longer if it had one. If your gonna play hard then for sure and of course after upgrades. Here is a pic of mine but I do belive that most people use different types and some with fans.
http://pg.photos.yahoo.com/ph/minema...59.jpg&.src=ph
shane361 is offline
Old 12-16-2005, 01:56 PM
ironh19
ironh19's Avatar
this is just a thought but if you are running 4.10s aren't you going to run out of RPMS by the time you get 4th gear, plus doesn't that also lower your top speed capability?
ironh19 is offline
Old 12-16-2005, 02:58 PM
Emann0007
Emann0007's Avatar
ORIGINAL: ironh19
No, That was a bad thought.
Emann0007 is offline
Quick Reply: Shift Kit ?
