Shift Kit ?
Old 12-16-2005, 03:02 PM
  #21
Matts00GT
Matts00GT's Avatar
Default RE: Shift Kit ?
I heard ppl say it did lower your top speed? Like 5-10 mph?
Matts00GT is offline
Old 12-16-2005, 03:11 PM
  #22
tripsevn7
Moderating with Angels
tripsevn7's Avatar
you will pull a couple hundred rpms higher with the 4.10's so i guess if you really max the car out, you will fall about 5-7 mph slower top end
tripsevn7 is offline
Old 12-16-2005, 07:04 PM
  #23
shane361
shane361's Avatar
Yes..if you run higher gears you will loose SOME top end. If your goal in life is to drive everywhere you go at 150mph instead of 145 mph then I DO NOT reccomend gears! However...if you are like MOST Mustang enthusiast then you would want higher gears in order to make it down the track or road alittle faster. 3.73 is an average gear MOST standard trannys go with and 4.10 gears are the average for auto's. If you go with 4.30s in a standard that might be out of the norm-Shane
My new signature needs to read....Sorry if you dont like my opinion..your fortunate enough to be entitled to yours[&:]
shane361 is offline
jwog666
12-27-2021 08:09 PM
Thunderball
15
11-22-2015 11:49 PM
Lethaldosage423
10-19-2015 12:12 AM
Explosive
10-02-2015 07:45 AM
Quick Reply: Shift Kit ?
