Can Stock Bottom End Hold This Much???
Old 12-16-2005, 12:19 AM
black01gt
black01gt's Avatar
Default Can Stock Bottom End Hold This Much???
Can A 99-04 4.6 gt hold 9psi? OR should be safely at 6? I ask this because i was planning on getting a Kenne Bell S/C.
black01gt is offline
Old 12-16-2005, 12:27 AM
01yellowgt
01yellowgt's Avatar
Default RE: Can Stock Bottom End Hold This Much???
stock block handle 450 hp. 9psi should be fine, just get a good tune. 9psi should put you about 400-420hp(depending on tune)
01yellowgt is offline
Old 12-16-2005, 12:53 AM
gt96stang
gt96stang's Avatar
It's not always about how much boost, but how much horsepower you are going to get from the boost. Yes, 450 Hp is all a stock block can take.
gt96stang is offline
Old 12-16-2005, 01:33 AM
Birdieman4
Birdieman4's Avatar
I have been making just under 440 rwhp in my 01 S281 for some time now, almost 30,000 miles since the blower install. The car is tuned to the hilt, though. I am quite confident I could get another 100k out of it, np.
Birdieman4 is offline
Old 12-16-2005, 02:31 AM
Dark_Horse
Dark_Horse's Avatar
Birdieman4 what blower do you have on your S281? and what color i think white saleens look awsome
Dark_Horse is offline
Old 12-16-2005, 03:07 AM
Voodoo
Voodoo's Avatar
ORIGINAL: Birdieman4
Awesome! That gives me a little hope. I figured if I got 20K with a blower I'd need a horseshoe up my ***. You better knock on wood now. : )
Voodoo is offline
Old 12-16-2005, 04:32 AM
Birdieman4
Birdieman4's Avatar
I am running a Procharger P1SC, making 9 psi. I'm really not worried at all. The keep the car in perfect tune. It is true blue. I have pics of it posted in the Saleen section. https://mustangforums.com/m_835138/tm.htm
Old 12-16-2005, 09:07 AM
xx9gt6xx
xx9gt6xx's Avatar
ORIGINAL: 01yellowgt
Agreed. Just be safe and take care of it and you'll have no problems...
xx9gt6xx is offline
Old 12-16-2005, 02:18 PM
nanaki
Retired MF Moderator
nanaki's Avatar
i'm running a vortech at 10psi just fine.
nanaki is offline
Old 12-16-2005, 02:41 PM
Birdieman4
Birdieman4's Avatar
To be perfectly honest, I think you could run 475 rwhp for some time, properly tuned. 475 at the wheels is quite a bit, and probably more than the accepted 'safe' level for 2v 4.6 motors. But I think it could be done with good results for quite some time, as long as there were no detonation issues, and the fuel delivery system was good.
Quick Reply: Can Stock Bottom End Hold This Much???
