Actual horsepower?
Old 12-18-2005, 04:14 PM
JT76
Moderator
JT76's Avatar
Default Actual horsepower?
I kno this has been asked before but real quick,,,,,, why is the Mustang GT advertised with 260hp when it actually gets significantly less? how do they get away with it? How much hp am i actually getting stock? How much for a V6(195hp as advertised i believe)? Are all automotive companies like this? I think thosed damned SRT4's are advertised as 230hp how much do they get? thanks
JT76 is offline
Old 12-18-2005, 04:16 PM
pj1010
pj1010's Avatar
Default RE: Actual horsepower?
What do you mean you get less? Have you taken your motor out and "dynoed" it?
pj1010 is offline
Matts00GT
Matts00GT's Avatar
It's called flywheel horsepower.
Matts00GT is offline
Old 12-18-2005, 04:17 PM
Bad04OrngGT
Bad04OrngGT's Avatar
Because that is flywheel hp.. then you loose power to the wheels because of drivetrain loss.. most stock gts were 225-230 i beleive to the wheels..
Bad04OrngGT is offline
Old 12-18-2005, 04:18 PM
pj1010
pj1010's Avatar
This dude has all theses performance parts and asked this question....what roads do you drive on so I can stay off of them,
pj1010 is offline
Old 12-18-2005, 05:30 PM
Hyper00
Hyper00's Avatar
ORIGINAL: pj1010
That is the product of more money than knowledge. You go to a mustang performance shop, throw down a grand, and say make me fast please. I'll be back tomorrow to pick her up.
Hyper00 is offline
Old 12-18-2005, 05:47 PM
sandcracker21
sandcracker21's Avatar
hahahahahahahahahaha
[sm=funnypostabove.gif]
sandcracker21 is offline
Old 12-18-2005, 07:16 PM
JT76
Moderator
JT76's Avatar
Thanks to all those who replied, I was just wondering about this, i didnt kno so I thought i would ask, I am only 19 and have limited experience with this, i am sorry i am not a genious and btw with the exception of the gears i installed everything myself (not many "mustang performance shops" around Buffalo NY) and more money than knowledge, haha well everything i have i work for in addition to going to college so the more money part is deff not true. When you dont know something i thought you ask and find out, isnt that what a forum is?
JT76 is offline
Old 12-18-2005, 07:30 PM
Lee Willis
Lee Willis's Avatar
No need to apologize and yes, this is what these forums are supposed to be for - not for beating up on people who ask questions. Everyone has to learn, and there are no dumb questions, only dummies who don't learn the first time and ask them again. You've done a lot of the work yourself, so keep it up.
SAE (Society of Automotive Engineers) has a way of defining what a car's HP rating means and how it is determined. Over the years they have updated this from time to time, most noteably in the early 70s when the convinced the whole industry to go from gross to net HP ratings -- a '70 427 Vette was rated at 435 HP gross but that same engine would be rated about 310 net.
How this is defined and what it means is pretty technical and takes pages to lay out specifically, but the important point is that it is an estimate of the power the engine produces when in the car, with the mufflers hooked up and while running all the standard equipment, what is called "at the flywheel." This is not easy to measure because you can't hook up a dynometer to the flywheel so most owners and shops measure it at the rear wheels. There, the car experiences some loses in power consumed by the transmission, U-joints, differential gears, axles bearings, and tires. All in all, most manual transmission cars loss about 11% to 15% from flywheel to drive wheels (GM M-6 cars a a bit better than most here, losing typically about 11%, Fords, about 3%, don't know why). Auto trans cars tend to lose an additional 3-5%: my 320 HP rated Porsche has the Tiptronic auto and did 265 RWHP - 17.2% loses.
You can reduce those loses slightly, very sligthly, by running a more expensive brand of synthetic lubricant in the trans and differential, but you would see only about 2 RWHP gain, at most.
Your Ford was rated at 260 HP flywheel by Ford, following its interpretation of the SAE standard in effect when your car was manufactured. Stock, with a manual trans, it probably dyno tested with about 225-230 RWHP, with an auto 220-225. Your car out to be doing a bit more than that. Have it tested and start keeping a record, then as you add more HP, you'll know what you are getting for your money and work.
Lee Willis is offline
Old 12-18-2005, 07:38 PM
pj1010
pj1010's Avatar
ORIGINAL: Lee Willis
No one was beating up on him. It was just...shocking.
pj1010 is offline
Quick Reply: Actual horsepower?
