Stuck throttle
Stuck throttle
I have a 2002 GT. The only mods are 70mm MAC TB, C&L intake plenum, K&N, and flows. Here's my issue. When I am accelerating real quickly (as most stang owners do) sometimes my throttle sticks at around 4K. This appears to only happen when I'm in gear. When I rev up to 4K in neutral it doesn't stick. When it does this I have to shutdown the car and pull over, pop the hood and shut the throttle body to full close. The throttle body isn't stuck open very much I would say less than 1/8 of an inch. The last thing done to my car was, I had the clutch replaced by a shop. I have reset the computer (by disconnecting the battery) and this still happens. Again this only appears to happen when I'm in gear. Would a bad TPS cause this or computer? Thanks for any input.
RE: Stuck throttle
My MAC TB did the same thing. The screws that hold the flap inside the TB are loose. Just tighten them and manually open and close ur TB quickly a few times to make sure it doesn't catch and you'll be all set.
RE: Stuck throttle
Your throttle body is just sticking open a little, it's not computer controlled, just mechanically. Like 9gt6 suggested just be sure everything is tightened down, and it should be ok.
Only the 05+'s are fly by wire.
RE: Stuck throttle
LOOSE SCREWS????If this is what you find be sure to use Red Loctite on them before you put everything back together.Be sure to repost and let everyone know what you find.Even a small screw running around inside your engine at high RPM'S could bend valves or poke holes in pistons.
RE: Stuck throttle
Well...I just finished taking apart everything and the screws were a little loose, don't know how loose it would have to be to do what XX9GT6XX says did to his Stang. I put some lock tite on it snugged up all the hardware on the intake plenum, TB and air intake. Going to take it out on the highway here in a little bit and see what happens. Wish me luck. Yeah...I don't think I'm buying MAC parts anymore...got this part off of Ebay (new) but still...
RE: Stuck throttle
ORIGINAL: lujandj
I only trust their exhaust.....how can you go wrong with pipes?
RE: Stuck throttle
Well...it appears to be okay now. But what I do have is a real annoying sound coming from the header area of the car. I only hear it when the car is above 45 MPH. This started up when my throttle was sticking. May I have blown a seal or gasket somewhere. I don't see any leaks, no fluid loss, I don't think I've lost any power...if I have I'm not noticing it. The sound is almost louder than my flows. I can barely hear my exhaust. If I did blow a seal or gasket somewhere...where could it be? It almost sounds like the Fan whinning really loud but I don't think the fan could out do my exhuast....What now?
Silver Bullet Stang
Silver Bullet Stang
RE: Stuck throttle
Silver Bullet Stang
Silver Bullet Stang
