does the winter bring out oil burning?
Old 12-20-2005, 01:03 PM
monkeydude3
monkeydude3's Avatar
Default does the winter bring out oil burning?
Hey all~
I have a 97 GT with a 5 speed. I bought it at the tail end of summer, and it ran great and as I checked it never used a drop of oil. Since winter hit, I drove about 1500 miles and here at work checked and added 1.5 quarts. We have had a lot of below freezing days lately, and I wonder if it's just because it's so goshforsakenly cold out that it burns more oil now? I do use the block heater and it does warm up quicker that way. But it has been run a lot on cold mornings. Any ideas let me know. She has lots of pep so I have a feeling my compression is solid.
George
monkeydude3 is offline
Old 12-20-2005, 02:46 PM
josh_0351
josh_0351's Avatar
Default RE: does the winter bring out oil burning?
I’ve noticed that mine is usually that low upon oil changes every 3K miles. I have been running 5W20 and decided to go with a little thicker-weight oil this last change – we’ll see if that makes a difference….
josh_0351 is offline
Old 12-20-2005, 02:57 PM
monkeydude3
hmmm... I'm running on 5W30... i still think it is a combination of milage and the cold weather. Maybe I can run 5 quarts of 5W30 and one quart of lucas? Anyone had success or problems with it?
George
Old 12-22-2005, 05:54 AM
Nitro Nick
Nitro Nick's Avatar
Well i Live in -10 to -40 weather up north in canada and even at those temps i'v been all good for the oil and in the gmc truck we run even a 0w 40 and that helps allot for those cold starts.
Nitro Nick is offline
Old 12-22-2005, 12:04 PM
monkeydude3
hmm
This is confusing because when I did a set of spark plugs 1000 miles ago none of them had ANY oily residue at all on them, but that was when it was warm out. That's why I think the cold weather may do it. I have 107k miles on it so I know it will burn some oil but it was weird 1500 miles and 1.5 quarts??
Should I start saving for a valve seal job? It will be about $500 to have all replaced. I figure if that is going to be the case I'm gonna price some aftermarket higher flow heads because why spend that much money on stock ones??
It runs so good though!!
George
Old 12-22-2005, 12:11 PM
monkeydude3
also will throwing in a quart of lucas with every oil change (5 oil 1 lucas) buy me a good amount of time? I have syncrhos to put in the trans and a clutch and some other stuff that has priority (and wheels)
I've heard good things about the lucas stuff
George
Old 12-22-2005, 12:15 PM
Derf00
Gentleman's Relish
Derf00's Avatar
ORIGINAL: monkeydude3
George
don't use any oil thickeners, they create sludge. The reason you're burning oil is that the colder it is, the more shrunk your valvestem seals are in the morning and the bigger the gaps between the piston rings and walls. Not much you can do about it other than make darn sure you warm your car up properly in the morning to minimize wear.
Derf00 is offline
Old 12-22-2005, 01:22 PM
monkeydude3
okay cool. So there's a good ch ance my engine is good it just reacts logically to the cold. I usually use the block warmer at night and let it run about 10 mins before driving every morning. Occasionally I can't but when I do driv eoff it's gentle acceleration and cruising.
Thanks
George
CS2007
06-25-2019 09:45 PM
baddog671
07-26-2016 01:20 PM
lincolnshibuya
12-08-2015 04:37 PM
jrrhd73must
10-02-2015 09:17 PM
wraith777
09-28-2015 10:49 AM
Quick Reply: does the winter bring out oil burning?
