Timming Adjuster/NO2
Old 01-14-2004, 12:16 PM
Craziness4fun
Craziness4fun's Avatar
Default Timming Adjuster/NO2
I've been looking into both for my car, however the more I look intoNO2 the more I see their companies warning that you must have stock timming. <IMG src=smileys/smiley5.gif border="0"></P>
If a nitrous system do I have to have stock timming, or is this just a precaution, If my timming ischanged will it increase the chance of my motor going bad?</P><edited><editID>Craziness4fun</editID><editDate>38000.9598032407</editDate></edited>
Craziness4fun is offline
Old 01-14-2004, 12:50 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
You actually want to retard the timing for nitrous.
Dan04COBRA is offline
Old 01-14-2004, 12:52 PM
N2OJunkie
I ♥ Acer
N2OJunkie's Avatar
Yes, you should have stock timing, if anything the timing should be retarded a few seconds to avoid detonation.......take your car to a shop with experience installing nitro kits and they will be able to help and guide you.Cold spark plugs may have to be installed too.
N2OJunkie is offline
Old 01-14-2004, 01:28 PM
O1stang
O1stang's Avatar
A diablo 3 program chip is a good idea. </P>
1.Stock program</P>
2.Performance advanced timing, tweaked A/F ratio.</P>
3.NO2 setting, when your car is armed and your NO2 activates at wot, this setting will pull timing and adjust other perameters as well at wot.</P>
Make sure you run the highest octancepumpgas as well anything to help prevent detonation.</P>
O1stang is offline
Old 01-14-2004, 04:46 PM
N2OJunkie
I ♥ Acer
N2OJunkie's Avatar
1.Stock program</P>
</P>
01 stang, Nice avatar man.......<IMG src=smileys/smiley16.gif border="0"></P>
Old 01-14-2004, 06:42 PM
O1stang
O1stang's Avatar
Thanks<IMG src=smileys/smiley2.gif border="0">
O1stang is offline
Old 01-15-2004, 12:58 AM
Craziness4fun
So basically, to run better NA I would like to bump the timming up but doing so would probabally mess up on NO2. Right?<IMG onclick="AddSmileyIcon'smileys/smiley25.gif'" height=12 alt=Question src=smileys/smiley25.gif width=12 border="0"></P>
Would a chip switch the timming (is that even possible) from one setting for na and one on NO2 while driving? <IMG onclick="AddSmileyIcon'smileys/smiley3.gif'" alt=Shocked src=smileys/smiley3.gif border="0">Or would that just retard it for me all the time? </P>
Gas wise mine's never tasted anythingbelow 93.<IMG onclick="AddSmileyIcon'smileys/smiley2.gif'" alt=Wink src=smileys/smiley2.gif border="0"></P>
Also if my timming is retarded to prevent detonation and I have colder spark plugs will that hurt me when I'm running na? and if so enough to notice, or worry about?</P>
Thanks</P>
Old 01-15-2004, 01:17 AM
O1stang
O1stang's Avatar
The diablo 3 prog. chip in one of the modes, specified by you (fill out their form),will pull timing atand only atwot when yourNO2 activates. It also adjusts other parameters during this time.</P>
You can switch between the 3 modes while driving. While running on the other program orNA performance program your timing will be advanced.</P>
So when you want to run Nitrous say at the track, switch to the 3rd setting and activate your nitrous system then you are ready to rock.</P>
Its ok todrive with colder plug for NO2 and NA.</P>
O1stang is offline
Old 01-15-2004, 04:22 AM
Craziness4fun
<IMG src=smileys/smiley1.gif border="0">Thanks, 01 stang, not only is your avatar awesome but the information you provided me is incredibly helpful. </P>
no2: what do you run with your setup with and w/o no2? how much are you spraying. Do you have a chip on yours?It looks like you and I have similar upgrades just different companies.<IMG src=smileys/smiley4.gif border="0"></P>
Thanks </P>
Rob</P>
Old 01-15-2004, 12:34 PM
N2OJunkie
I ♥ Acer
N2OJunkie's Avatar
</P>
</P>
I am still doing a 75 shot, I haven't done any Dyno checks yet, but I will . I am probably at 300 rwhpor a litle above with the N2O shot.</P>
Quick Reply: Timming Adjuster/NO2
