G-TECH INFO (i hope is wro
Old 01-15-2004, 03:31 AM
96mustanggt46
96mustanggt46's Avatar
Default G-TECH INFO (i hope is wro
I just barrowed my freinds G-TECH to test my 1/4 mile times and it was 15.9 WTF why is my car so f**king slow it pisses me off <IMG style="WIDTH: 17px; HEIGHT: 15px" height=3 src=smileys/smiley7.gif width=17 border="0"> i thought it was going to be at least 15.3 at the slowest is it because i live in SLC Utah where it is high and the air is thinneror does that even matter much what can i do to get it to low 14s will a pi head swap get me near there. any info will help thanks</P>
96mustanggt46 is offline
Old 01-15-2004, 03:43 AM
USAMuscle
USAMuscle's Avatar
You'll pick up 60-80 horses with a PI head swap. It's the best bargain for power you'll get. The only other thing that will boost your HP that much is a blower which costs upwards of $3,000, and nitrous, which has it's own consequences if used carelessly. A PI head swap can be done for less than half that of a blower, and IMO it's a much better mod, because it's best to start from the bottom up when modding your car. High flowing heads will help out all future add-ons.</P>
USAMuscle is offline
Old 01-15-2004, 04:10 AM
96mustanggt46
Where do you suggest i should get pi heads frome?
Old 01-15-2004, 05:02 AM
T5superduty
T5superduty's Avatar
Also depends if you were going up a hill or not...its really meant to be tested on flat ground. But the G tech is really accurate so do not doubt it either. I took mine to the track and got the exact same time just the miles per hour was off by 2
T5superduty is offline
Old 01-15-2004, 10:54 AM
hotrodman
I ♥ Acer
hotrodman's Avatar
i have a veiricom computer its very accuarte but when you go to track you will always run faster ,more traction there.at just gives you a baseline.for tuning once you get it tuned right ,go to the track .that the way you find out ,some their is bound to be running faster so dont be upset<edited><editID>hotrodman</editID><editDate>38001.6425347222</editDate></edited>
hotrodman is offline
Old 01-15-2004, 04:17 PM
BlackGT03
BlackGT03's Avatar
</P>
</P>
my buddy had a 96 GT convert. his best was like a 15.2, he had a chip, K&amp;N, flowmasters and gutted cats. Also, the higher you are in altitude the slower you will run, because the air is thinner it makes for a richer condition, which in turn will slow you down some. </P>
BlackGT03 is offline
Old 01-15-2004, 05:06 PM
karma279
karma279's Avatar
Yeah, the 96-98 aren't that quick. That's prob pretty accurate. Do the head swap and some 4.10's. You'll come down!
karma279 is offline
Old 01-15-2004, 05:48 PM
hotrodman
I ♥ Acer
hotrodman's Avatar
im going to run my truck tonight on it let you know by 7:00pm
Old 01-15-2004, 10:32 PM
hotrodman
I ♥ Acer
hotrodman's Avatar
okay ran my truck on the vericom, took out my 4.30s,gas milegae sucked my 3.27s are no better i have some 4.10s going to put in next these are my times 83f100 351W,edel rpm heads,,0-60,,5.8 seconds. quarter mile,,13.6/106mph.on all terrain tires.12.5x31x15s, those 3.27s killed me ,,4.30s at track ran 12.56/112mph..was running out of rpms.4.10s should do great,,<edited><editID>hotrodman</editID><editDate>38003.14875</editDate></edited>
Old 01-15-2004, 11:34 PM
RJM02GTDrag
RJM02GTDrag's Avatar
For your car you can do a lot before swapping the heads. Looks like you need a bigger Mass air kit 80 mm, throttle body 75mm, plenum, headers, x or h pipe and 3:73 or 4:10 gears. You will also do better with some drag radials, good luck.
RJM02GTDrag is offline
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
breaking
10-02-2015 01:27 PM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
RCS02v6
09-29-2015 01:46 PM
junior04
09-28-2015 10:53 AM
Quick Reply: G-TECH INFO (i hope is wro
