94-98 Mustang Passenger Airbag removal DIY - MustangForums.com
Old 01-15-2006, 11:41 PM   #1
mac_24_seven
Default 94-98 Mustang Passenger Airbag removal DIY
I searched ans earched and asked questions and never got ab answer. So, this is for the pple who actually use the search button and can do what I was looking for.
I knwo this works on the sn95's but I'm unsure if it will work on the eagle bodys. So here goes:
Tools needed: 7 mm and 8 mm sockets and a 7 MM wrench.
Remove the glove compartment, there are te bolts. Use the 7 mm socket to get em out.
After thats out, you have to move the vent hose out of the way a lil bit, but don't need to remove it.
Then there are 2 bolts that hold the airbag in: Use a 8 mm wrench, after they are out, the airbag just lifts out. I\'m not replacing it, so I wasn't worried about the lil sensor or anything, so I just cut the yellow wire that's connected to the airbag.. and bam. it's done.
Hope this helps somoene else out.
It's that simple
mac_24_seven is offline   Reply With Quote
1995 Mustang GT- 8.8 Overhaul Urambo Tauro 5.0L (1979-1995) Mustang 22 09-07-2015 01:47 PM
Installing new hood jlopez07 2005-2009 S197 Appearance Section 1 08-21-2015 10:28 AM
65 Mustang Upholstery from different vendors MtnMustang Classic Mustangs (Tech) 2 08-16-2015 09:07 PM
Just swapped motor exhaust want fit daytooday Motor Swap Section 2 08-11-2015 10:22 AM
2015 Mustang Oil Change Help OBleedingMe The New S550 2015-2017 Mustang 0 08-08-2015 01:02 PM
1996, 9498, 95, 98, airbag, airbags, cobra, delete, diy, instruction, mustang, passenger, removal, remove, replacing, sn95
