99 Cobra vs 99 GT - Page 3 - MustangForums.com
Old 03-13-2006, 07:20 PM   #21
GSXRIntensity
Default RE: 99 Cobra vs 99 GT
Quote:
ORIGINAL: Dan04COBRA
Good post.
Agreed. I learned quite a bit from it.
GSXRIntensity is offline   Reply With Quote
Old 03-21-2006, 11:13 PM   #22
GT35thconvertable
well one thing i see that isnt true is the 99 gts come with a 8 bolt flywheel..99 - mid 01 just thought I would add that just pulled the motor for forged internals
GT35thconvertable is offline   Reply With Quote
Old 07-26-2006, 06:02 PM   #23
SagaciousBrent
Just to let you guys know, the stock crank in my 99 GT had 8 bolts, not the 6 that was in this post.
SagaciousBrent is offline   Reply With Quote
Old 07-26-2006, 06:44 PM   #24
bsteen81
Quote:
ORIGINAL: SagaciousBrent
Thats a windsor motor.
bsteen81 is offline   Reply With Quote
Old 07-26-2006, 06:55 PM   #25
droptoppony
Quote:
ORIGINAL: bsteen81
99 was a windsor motor
and 99 gt did have 8 bolt cast
and 99 Cobra had 8 bolt forged crank
droptoppony is offline   Reply With Quote
Old 07-26-2006, 07:00 PM   #26
droptoppony
Quote:
ORIGINAL: ShadowDrake
Quote:
ORIGINAL: 2VNA
I was reading that there is a cooling problem on the 4.6 heads, causing 7 & 8 to over heat. It's a flow problem and can be resolved but they said you have to pull the trans to do it. I would post the link but it's on another board and I don't think that would be to cool.
Say WHAT?
There's a problem with the heads, so you need to pull the transmission? Stop to think about it for a second. The heads can be pulled without removing the engine.
I haven't heard of this problem, and 7 & 8 are usually not trouble cylinders... You would have to be running your stang real hard all day to have a problem with it I would think.
Yes definately a cooling issue with the #7&8 because of poor coolant flow. Some guys will run a 1 step cooler plug in 7 & 8 to help with this. Search for the Coolant mod on Mod Depot and you'll find a few how to threads with pictures. It is really hard to do with the engine in the car.
I'll be doing it myself when the new engine is ready to go in.
Old 07-26-2006, 07:50 PM   #27
FWP!
Quote:
1999 Cobra: Hypereutectic cast alloy shallow skirt with friction reducing coating on sliding surfaces
1999 GT: ???
Not really.
Cobras starting in '99 used flat topped forged pistons, the GT's used the Hypereutectic cast alloy shallow skirt with friction reducing coating on sliding surfaces. I know this because I just had to replace one of the pisons in my '00 GT '99 GT's had SLIGHTLY less compression compared to '00, like a few tenths of a point difference.
FWP! is offline   Reply With Quote
Old 09-23-2006, 10:47 PM   #28
SleepingGT
2000 gt's have 8bolt also
SleepingGT is offline   Reply With Quote
Old 09-23-2006, 11:00 PM   #29
snakeman4life
Quote:
ORIGINAL: slow99GT
I am really not to impressed with the 99 cobras.. my neighbor had one with a long list of bolt ons and i walked him with my 99GT that has exhaust and intake!! a month later he sold it and got a 03 cobra.. now the tables have turned[]
Someone couldn't drive their Cobra,of should have fixed whatever was wrong with it.
snakeman4life is offline   Reply With Quote
Old 10-27-2007, 01:10 PM   #30
99StangAnd02R1
Dunno bout that. I have a 99 GT and have an 8 bolt crank to flywheel match.
99StangAnd02R1 is offline   Reply With Quote
A Peek at the S550 Mustang Cobra Jet MustangForums Editor Mustang News, Concepts, Rumors & Discussion 3 11-10-2015 11:39 AM
TNT weekend - No PB, just fun..... 88 orangepeel notch Street/Strip 4 10-05-2015 09:03 AM
WTB: 03/04 Cobra wheels - or 18x10rear/18x9f set Dan04COBRA Want To Buy Ads 1 09-30-2015 11:46 AM
need traction mikesr4565 Suspension 5 09-21-2015 10:26 AM
2000 Cobra R front bumper Sparks_88 4.6L (1996-2004 Modular) Mustang 0 09-08-2015 01:06 PM
1999, 46, 99, 99gt, cobra, difference, end, engine, gt, mustangpartscom, performance, rear, recall, specs, timing
