? where is the fuel pump fuse?
Old 02-08-2006, 04:19 PM
wildazme
wildazme's Avatar
Default RE: ? where is the fuel pump fuse?
in the chiltons it says its fuse #15 and its saying its a maxi fuse, i dont have a 20amp maxi fuse where its showing me its suppose to be.
wildazme is offline
mustang_montana
mustang_montana's Avatar
you dont need to pull any fuses, its mostly a disclaimer to cover their asses. they also tell you to pull the fan fuse too, not necessary. in certain cars like the focus i think it was, the battery died during programming due to the drain. but with stangs the reflash is really fast and wont come anywhere near draining the battery.
mustang_montana is offline
Old 02-08-2006, 04:22 PM
wildazme
wildazme's Avatar
its saying in the instructions that if i dont pull the fuse severe engine damage can occur, also during the programing it asks if your sure you removed the fuse.
wildazme is offline
Old 02-08-2006, 04:25 PM
mustang_montana
again its just a disclaimer, i use the sct2 though but its the same idea. i couldnt figure out which one was for the fuel pump either, though. sorry man.
Old 02-08-2006, 04:29 PM
wildazme
wildazme's Avatar
so you did it without pulling the fuse even though it said not to and it was fine?
wildazme is offline
Old 02-08-2006, 04:50 PM
mustang_montana
yeah, no problems at all. did it like 4 times.
Old 02-08-2006, 05:06 PM
The Great Cornholio
I ♥ Acer
The Great Cornholio's Avatar
ORIGINAL: wildazme
Sounds like the Superchips Max Microtuner
The Great Cornholio is offline
Old 02-08-2006, 07:15 PM
wildazme
wildazme's Avatar
it is the superchips max micro tuner, i called the company and they told me to disconnect the fuel pump by pulling the wiring harness from the fuel cutoff switch in the trunk. I did and installed the tune and i have to say its great you can really feel the difference right away when driving.
wildazme is offline
Old 02-08-2006, 08:05 PM
The Great Cornholio
I ♥ Acer
Good deal
piotrek53
10-13-2015 06:54 PM
svfetter
10-05-2015 11:39 AM
b8checker
09-30-2015 07:11 AM
LiquidDrink
09-29-2015 10:06 AM
SteelerNation82
09-16-2015 07:11 AM
Quick Reply: ? where is the fuel pump fuse?
