Mass air
Mass air
Oops what I meant was what do I need to do to keep the fuel system to make up for the change in the air ratio or is it not so big of a deal yet to make it run lean? I am a total newb when it coems to most of this.
Mass air
</P>
I have the same set up and you need to do nothing. Just make sure you take off the battery lead during install and don't put it back on until you're done. This will make the computer "learn" what you did.</P>
Get the 75mm TB if you go with the C&L plenum. That is what they did all the dyno testing with. Also if it is true that C&L is making a lower, you'll want the 75mm TB</P>
</P>
Mass air
It is really nice, I will try to find the videos I saqw before I bought mine or I will use my sisters camera to make a short video. It is really loud at full throttle and has a nice rumble to it
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
