Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-17-2007, 10:11 PM   #31
iamyourdaddy26
Default RE: The home-made MIL's work! *pics*
i think it is actually harder to instal the mil's themselves then to make that piece. the drivers side is easy i had to get a girl to grease up her arm to put in my passenger side mil it took her about 20 mins but it worked and i havnt had a problem since. the car deff runs like poopie whent the CEL is on. nice work my friend
__________________
iamyourdaddy26 is offline   Reply With Quote
Old 03-06-2008, 08:42 PM   #32
TRMach
Quote:
ORIGINAL: Brute03
okay, i've added the schematic for those of you that asked. once you get the pc board that's required the finished product will look much cleaner
I just picked up an off road H-pipe and have also gotten the parts from Radio Shack to make these MIL's. Question is how would this set-up look with the PC board? I've done plenty of wiring but have never used a PC board and was just wondering how it would be done. Thanks.
__________________
'04 Torch Red Mach 1
TRMach is offline   Reply With Quote
Old 03-06-2008, 08:51 PM   #33
banginstang07
Vehicle: 2003 Mustang GT
Thanks for the info I also found that site through google. I just got my o/r x in the mail i plan on making them sometime in the next week
__________________
2003 Mustang GT - SLP LM II's, O/R X, MGW Shifter, Eibach springs, Mach 1 Grill Delete & Chin Spoiler, 6K HIDs, JLT CAI, BBK 78mm tb / plentum, SCT tuner, 4.10s, 04 cobra seats
Best time: 13.812 @ 101.35----242rwhp 272rwtq
New times and numbers with new mods coming soon
banginstang07 is offline   Reply With Quote
Old 03-07-2008, 02:40 PM   #34
josh.davis
make this a sticky
__________________
1999 gt-373 gears- off road h-pipe- Electric water pump- bbk cold air intake- 75mm throttle body- trick flow elbow- grantile 0ohm connetors-75/150 shot NOS-
MT-Drag radials-xcal 2- B/M short throw shifter.
josh.davis is offline   Reply With Quote
Old 03-07-2008, 03:27 PM   #35
99gt302
Vehicle: 1999 Ford Mustang Cobra
Send a message via AIM to 99gt302
heres a pic with PC board....
[IMG]local://upfiles/83512/98DBC492EABC41E78B92B7AB5D229DCA.jpg[/IMG]
[IMG]local://upfiles/83512/0DC9C19CBF854EEE98709AB74B899C9A.jpg[/IMG]
__________________
99gt302 is offline   Reply With Quote
Old 03-07-2008, 05:55 PM   #36
cliffyk
cliffyk's Avatar
Here's my writeup on DIY MIL eliminators, we used to use 'em all the time on the later model Miata's.[/align][/align]There's no need to worry about the 1/4W resistors. First off the maximum voltage out of a O2 sensor is less then 1.0V, and the resistors are 1.0 MΩ...[/align][/align]Watt this all means is that the maximum power the resistor will ever see is 0.001 mW, or 1/1,000,000th of a Watt.[/align][/align] W = (E²/R)which is\n this case = (1²/ 1,000,000) = 0.000001, or 0.001 mW.[/align][/align]The maxiuum current is 1/1,000,000th of an ampere (E/R) or 0.001 mA; or ... 1/20,000th of 20 mA...[/align][/align][/align]
__________________
-cliff knight-
My Mustang
2003 GT, UPR X, Magnaflow, 180° stat,
PP 70mm TB & plenum, Sniper tuned
3.73s, 262 rwHP/305 ft.lb.
Multi-fuel: burns gas and rubber...
cliffyk is offline   Reply With Quote
Old 03-08-2008, 10:40 PM   #37
blownbayou
Make sure you heat wrap the MILs TIGHT!!!! Water will give you hell!!!!
Later and good work
__________________
2000 White Lightning w/mods
http://media.putfile.com/Lightning-Exhaust
2002 Mustang GT IMCO 1 chambers w/Stock H less rear cats
blownbayou is offline   Reply With Quote
00, diy, doityourself, eliminator, eliminators, gt, homemade, inspection, mil, mils, mustang, o2, pics, s197, state, xpipe, york
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
