Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-05-2007, 03:41 PM   #101
greatjedi
Default RE: Bad Boys of the 4.6 Section
2003 GT 5 Spd
SSS catback
Pypes o/r X
75mm Accufab throttle body and plenum
JLT ram air intake
Steeda underdrive pullies
Maximum Motorsports full length subframe connectors
FRPP "C" springs
Tokico HP shocks and struts
Steeda X2 ball joints
SCT Xcal tune by Heath @ Modular Madness West
3.73 FRPP gears
MGW short throw shifter
MGW Gripper shift knob, e-brake handle, & door lock pins
Mach 1 Grille delete
Mach 1 chin spoiler
18x9 Chrome deep dish bullets
Toyo Proxes 4 all season performance tires
__________________
2003 DSG Mustang GT
SSS Catback, Accufab 75mm TB/Plenum, JLT RAI, Steeda UDPs, MGW shifter, FRPP C-springs, Tokicos, Steeda X2 ball joints, Xcal 2, MM full length subframes, 3.73 gears
greatjedi is offline   Reply With Quote
Old 07-05-2007, 04:16 PM   #102
mills281e
Vehicle: 2002 Saleen S281 Extreme
Stock S281 Extreme Performance Enhancements:
[ul][*]Saleen Series V twin-screw (Whipple)intercooled supercharger[*]Saleen forged steel crankshaft w/ Saleen forged steel rods and forged aluminum pistons[*]Heads: Aluminum with Saleen special cam shafts, super duty valve springs[*]Saleen water-to-air intercooler with heat exchanger[*]Saleen cold air induction system and performance air filter[*]42lb/hr sequential fuel injectors[*]Exhaust System: Stainless steel 2.5" 4-way catalytic high flow with X-pipe[*]Quick ratio 6-speed manual transmission[*]11" aluminum flywheel with 11" full asbestos clutch disk[*]Balanced custom drive shaft
[/ul]
Racecraft Suspension
[ul]
Front:[*]Saleen N2 Struts[*]Variable rate springs mounted on lower control arms[*]1.38" stabilizer bar with urethane pivot bushings
Rear:[*]Live axle four-bar link[*]Racecraft variable race coilsprings on boxed lower trailing arms[*].94" stabilizer bar[*]Quadra shock system[*]Saleen N2 shocks and axle dampeners [/ul]
Aftermarket Upgrades:
[ul][*]SCT 4-bank chip with custom tune[*]SCT 90 mm MAF[*]Chicane Intercooler[*]Chicane 2.6" pulley (original= 4")[*]Accufab 70 mm TB[*]Kenne Bell Boost-A-Pump[*]Highflow cats[*]3.73 gears (original = 3.08)[*]NGK-BR7EF Plugs[*]Redline Water Wetter in intercooler reservoir and radiator[/ul]
440RWHP/484 RWTQ
__________________
2002 Saleen S281 Extreme #46
Chicane Intercooler & pulley; SCT Chip & Tune; 3.73's; 90mm SCT MAF; 70mm ACCUFAB TB; KB Boost-A-Pump; Spec Stage 3 clutch, High-flow cats; built & tuned by Modular Powerhouse
1997 SVT Cobra #5726 (SOLD)
mills281e is offline   Reply With Quote
Old 07-06-2007, 01:36 AM   #103
03greyGT
03greyGT's Avatar
Vehicle: 2003 Mustang GT
Send a message via AIM to 03greyGT
lots of nice cars on here!
__________________
03 GT, full bolt-ons, cammed, gears...
03greyGT is offline   Reply With Quote
Old 07-09-2007, 11:39 PM   #104
Quicktime_GT
is 395rwhp enough to be a bad boy ?
__________________
P1SC, 3 core, bolt ons
416/400
12.4@ 114- 2.1 60'
Video
Quicktime_GT is offline   Reply With Quote
Old 07-12-2007, 05:55 PM   #105
ZW99GT
Moderator
ZW99GT's Avatar
Vehicle: 1999 GT
Quote:
ORIGINAL: Quicktime_GT
Lol, that's more than enough man.
__________________
Stock 351W
ZW99GT is offline   Reply With Quote
Old 07-12-2007, 05:59 PM   #106
ZW99GT
Moderator
ZW99GT's Avatar
Vehicle: 1999 GT
BUMP!!!!!! Just added about $2500 worth of mods to mah list![sm=helpout.gif]
__________________
Stock 351W
Old 07-13-2007, 01:35 PM   #107
Quicktime_GT
Quote:
ORIGINAL: ZW99GT
haha ..
03 4.6 2v GT 5 speed
Engine/ Drivetrain :
[ul][*]Procharger P1SC (shiney) 3.4 inch pulley 10psi @5600[*]Procharger 3 core intercooler[*]ford svt focus 255lph pump[*]42lb injectors[*]Pro M mass air meter[*]full length headers, mac o/r prochamber, magnaflow magnapack cat back[*]BBK throttle body[*]SCT dyno tune by speedydyno - speedydyno.com[*]dynojet #s 395rwhp/ 435rwtq http://i37.photobucket.com/albums/e8...no/dyno013.jpg[*]frpp 4.10 gear[*]Centerforce DF clutch[*]26x11.50/16 ET streets for the track [/ul]Cosmetic
[ul][*]ford 03/04 cobra bumper , hood[*]FR500 replicas from americanmuscle.com 17x9 & 17x10.5 with 245/45/17s and 315/35/17s[*]BBK springs with no front spring isoloators[*]Stainless steel "mustang " inserts[*]5% tint[/ul]Interior
[ul][*]Procharger embroidered black/grey leather[*]boston sx60 component front door speakers[*]kicker KX600.1 amp for subs[*]Sony amp for components[*](2) Kicker 8 inch L5 solobarics 136.7dB[*]pioneer deh p8400, direct iPod connection, sirius[*]UPR shifter with 05 knob [/ul]Car has went 12.4 @114 w/ 2.2 60' . shooting for low 12's or maybe even 11's on slicks in 08'
__________________
416/400
12.4@ 114- 2.1 60'
Video
Old 07-17-2007, 10:31 PM   #108
LetThePoniesRunFree
2001 Mustang GT:[/b]
Engine:[/b]
Kenne Bell 2.1 Intercooled Twin-Screw Supercharger
MMR Built 4.6 Short Block
CNC Ported / Polished Factory Heads
Custom Grind Comp Cams Camshafts
Kenne Bell Boost-a-Pump
Custom SCT XCAL2 Tune by Lasota Racing
BBK 75mm Throttle Body
Ford Focus SVT Fuel Pump
FRPP 42 lb/hr Injectors
Ford Lightning 90mm Mass Airflow Meter
LFP Heat Exchanger
Ford Lightning Intercooler Pump
Fluidyne Racing Radiator
PA Performance 200 Amp Alternator
Tunable Induction CAI
Canton Aluminum Expansion Tank
Canton Aluminum Intercooler Reservoir
Zeitronics Wide-Band Air / Fuel Ratio Meter / Data logger
Optima Red Top Battery (relocated to the trunk)
NGK TR-6 Spark Plugs
Drivetrain:[/b]
Tremmec 3650 5 Speed
MGW Short-Throw Shifter
Spec Stage 2 Clutch
Spec Billet Steel Flywheel
FRPP 3.73 gears
FRPP 31 Spline Rear Axels
FRPP 31 Spline Traction-Lok
FRPP Aluminum Driveshaft
Custom Mandrel Bent 2.5" Exhaust with 10 Series Flowmaster Race Mufflers
Suspension / Chassis: [/b][/b]
2001 Bullitt Springs / Struts / Shocks / Sway Bars
Maximum Motorsports Sub-Frame Connectors
Granatelli Upper / Lower Rear Control Arms
FRPP Cobra (13" Front / 11.65") Rear Brake Conversion
Goodridge Stainless Steel Brake Lines
Wheels Tires: [/b]
Front: 255 45 17 Kumoh Ecsta on 17x9 Bullitt Deep Dish
Rear: 315 35 17 BFG G-Force Drag Radial on 17x10.5 Bullitt Deep Dish
Interior: [/b]
Full Complement of Autometer Gauges
Autometer Two Gauge A-Pillar Pod
Autometer Two Gauge Instrument Cluster Bezel Pod
Raptor Shift Light
Exterior: [/b]
Shorty Radio Antenna (worth 15 rwhp)
FRPP Mach 1 (3) piece Grill Delete
FRPP Mach 1 Chin Spoiler
Misc: [/b]
Red-Line Racing Oils Used Exclusively
Future Mods: [/b]
Methanol / Water Injection
Carrera Racing Seats
Interior Roll Cage
__________________
IC KB 2.1 and the list goes on......
SCT Tuned by Lasota Racing Technologies
http://www.lasotaracing.com/
Never Bring Show To A Go Fight
LetThePoniesRunFree is offline   Reply With Quote
Old 07-29-2007, 11:35 PM   #109
white venom
baby poop
white venom's Avatar
Send a message via AIM to white venom
2000 mustang gt
steeda cold air intake
flowmaster super 40s
steeda pulleys
motive 3:73s
im a newbie
__________________
2000 gt vert-flowmasters 40s, Steeda underdrive pulleys, JLT intake, SCT SF3, 4.10s, intake spacer (lol)
Quote:
Originally Posted by Dan04COBRA View Post
MY THUMB WENT KNUCKLE DEEP IN HIS ANUS!!!
white venom is offline   Reply With Quote
Old 08-20-2007, 07:39 PM   #110
ben790450
I ♥ Acer
Send a message via AIM to ben790450 Send a message via Yahoo to ben790450
Remember guys this is for the "Bad boys" of the 4.6 section. Having gears, a CAI, and a catback doesnt make you a bad boy
ben790450 is offline   Reply With Quote
17inchalumastar, 4, aluminum, arms, autometer, automotive, bell, drag, driveshaft, gt, kenne, mmr, onepiece, powerhouse, racing, tubular, weld, wheels, wideband
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
