Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 12-28-2006, 07:32 PM   #41
muzikp
Default RE: Bad Boys of the 4.6 Section
BBK long tubes
BBK catted H pipe
BBK CAI
BBK plenum
BBK TB 70mm
Magnaflows 2.5"
Steeda pullies
4.10's
Nex 100 shot
Eibach prokit
FRPP racing pedals (4)
King Cobra HD
Autometer gauges Lunar gauges + A/F gauge and Nitrous pressure
17x9 and 17x10.5 Cobra R's
Nitto 555R 245/45/17 - 305/35/17
Optima red top
Diablo tune
HID
Oh and ahorse power increasing shorty antenna +150 pounds of stereo stuff.
Never been to the track/dyno so I have no idea on numbers, but I know it's not enough to be considered one of bad boys!!!
__________________
muzikp is offline   Reply With Quote
Old 12-28-2006, 10:37 PM   #42
ben790450
I ♥ Acer
Send a message via AIM to ben790450 Send a message via Yahoo to ben790450
- delete-
ben790450 is offline   Reply With Quote
Old 12-31-2006, 04:48 AM   #43
Machwon
2000 Sunburst Gold GT-61,000Miles -390/414 with conservative tune.[/align]Im sure i'll miss like a thousand things but oh wells...[/align]PERFORMANCE:[/align]ATI P1-SC Procharger w 8lbs [/align]2 Core air/air intercooler[/align]Accufab 75mm t/b[/align]C & L Plenum[/align]Steeda intake spacer[/align]SVT Fuel pump[/align]FRPP 42lb injectors[/align]BBK equal length headers[/align]BassaniCatted X pipe[/align]SLP Loudmouth 2 Catback[/align]MGW Orange handle shifter[/align]SCT custom (dyno) tune/ chip[/align]FR 31 Spline Axles[/align]FR 31 Spline Traction Lok Differential[/align]Ford Racing 3.73 gears [/align][/align]SUSPENSION:[/align]Sprint lowering springs (2.0" drop)[/align]Bilstein HD Shocks & Struts[/align]Energy suspension poly bushings (front)[/align]Granatelli Upper control arms[/align]UPR Chrome Moly HD Lower control arms[/align]Blue Oval Industries Subframe connectors[/align][/align]LOOKS:[/align]2"drop[/align]03/04 Cobra front bumper[/align]17X9 & 17X10.5 Bullitt Wheels (black)[/align]275/40/17 Pirelli P Zero Nero Corsas (front)[/align]315/35/17 Nitto 555R Drag radials (rear)[/align]Mustang Tuning Shorty blackantenna[/align]Mach1 smoked headlights[/align]02+ GT sidescoops[/align]MRT Hood Struts[/align]Ford strut caps[/align]Stock rear Spoiler moved back 2 inches[/align]CDC Honeycomb Panel[/align][/align]INTERIOR:[/align]MRT Interceptor Gauge Cluster[/align]Autometer Boost gauge[/align]Autometer Fuel Pressure Gauge[/align]AEM UEGO Wideband Gauge[/align]Steering column Gauge pod (boost)[/align]Dual A-Pillar pod (AEM & Fuel Pressure)[/align]Ford Racing Aluminum 4pedal set (mach/cobra)[/align]Raptor shiftlight[/align]MGW E-Brake handle cover[/align]MGW "GT" Shift knob[/align]Various dash and door UPR billet pieces[/align][/align]
__________________
2003 Torch Red Mach 1
492rwhp / 434rwtq
Machwon is offline   Reply With Quote
Old 01-02-2007, 03:10 PM   #44
newb2000GT
2000 Mustang GT
ATI ProCharger - 8 psi
ATI 3-Core Intercooler
FRPP 42# Injectors
Walbro Fuel Pump
A-Pillar Gauge Pod w/Autometer Boost Gauge & AEM Wideband Air-Fuel Gauge
Steeda Tri-Ax Shifter
King Cobra Clutch
MagnaFlow Tru-X Catted Midpipe
MagnaFlow Catback
Maximum Motorsports Weld-In, Full-Length Sub Frame Connectors
398 rwhp / 411 rwtq on a Mustang Dyno.
__________________
2000GT - Tri-Ax,MagnaFlow Tru-X/Catback,P-1SC @ 8psi w/3-core IC,King Cobra clutch,MM fullength SFC's: 398 RWHP/411 RWTQ on Mustang Dyno
newb2000GT is offline   Reply With Quote
Old 01-03-2007, 11:34 PM   #45
Lord Ashram
Okay, here goes. I am leaving off the basics (fluids and the other stuff) and the looks; that stuff doesn't add horsepower
Rebuilt 4.6 with all forged internals and a cobra crank.
Rebuilt five speed tranny.
Vortech s-trim at 10lbs.
Steeda stage 1 and 2 suspension kit.
Kenny Brown subframe connectors
9.5x17 American Racing front wheels, 11x17 rear.
315 Sumis out back, 275s? up front.
3.73 Ford Racing gears.
255 intank pump
Mass air meter
42lb injectors
Centerforce clutch
Baer 13.5 inch front brakes
Steeda Triax shifter
Bassani X pipe, flowmasters.
Superchips chip (I think it is superchip, been a while since I looked )
I think that is it.
420.something rwhp
425 torque
Throttle body and some other basic stuff I am forgetting about
Lord Ashram is offline   Reply With Quote
Old 01-05-2007, 07:43 AM   #46
DarkSoul
- Engine -
- Kenne Bell 1.7 TwinScrew Supercharger
- Kenne Bell Big Tube Kit
- Kenne Bell Cold Air Intake
- Accufab 75mm Throttle Body
- K&N Air Filter
- FRPP 90mm Mass Air Meter
- FRPP 42 Pound Injectors
- Cobra Dual Fuel Pumps & Tank
- CMR Diablo Flip Chip
- BBK Chrome Long Tube Headers
- Magnaflow Cat Back
- Mac o/r Pro Chamber
- NGK tr6 Spark Plugs
- Canton Oil Pan
- Canton Windage Tray
- Odyssey Battery
- Cooling -
- Xtreme Motorsports Heat Exchanger
- Xtreme Motorsports Dual Heat Exchanger Fans
- Precision Fab Reservoir Tank
- Meziere Electric Water Pump
- Red Line Water Wetter
- DriveTrain -
- Detroit True Track Differential
- Moser 31 Spline Axles
- FMS 3.55 Gears
- Moser Rear End Girdle
- Suspension -
- Steeda Sub Frame Connectors
- Maximum Motorsports K-member
- Maximum Motorsports Tubular A Arms
- Maximum Motorsports Front Coilover Kit
- Maximum Motorsports Aluminum Steering Rack Bushings
- Maximum Motorsports Adjustable Tie Rod Ends
- Maximum Motorspots Camber Caster Plates
- Maximum Motorsports 2 Point K-member Brace
- Maximum Motorsports Rear Adjustable Lower Control arms
- Tokico Illumina 5 Way Adjustable Drag Struts
- Tokico Illumina 5 Way Adjustable Shocks
- Energy Suspension Motor Mounts
- Energy Suspension Transmission Mount
- Energy Suspension Rear Spring Isalators
- Prothane Sway Bar End Links
- Brakes -
- Front -
- Brembo Four Piston Calipers
- Brembo Slotted Disc
- Goodrich SS Brake Lines
- D.O.T. 5 Brake Fluid
- Rear -
- Stock
- Exterior -
- CDC Mach 1 Grill Delete
- Mach 1 Chin Spoiler
- Kirban Shorty Antenna
- Redline Hood Struts
- Cobra Heat Extraction Hood
- Interior -
- Corbeau Trs Black Microsuede Seats
- Corbeau Mounting Brackets
- Rear Seat Delete
- Steeda Billet Window Switches
- Steeda Billet A/C Knobs
- Bullitt Pedals
- Autometer Steering Column Pod
- Autometer Triple Pillar Pod
- Autometer Ultralite Boost Gauge
- Autometer Ultralite Water Temp Gauge
- Autometer Ultralite Air/Fuel Gauge
- Autometer Ultralite Fuel Pressure Gauge
- Autometer Ultralite Nitrous Pressure Gauge
- Wheels -
- Front -
- 18x9 Chrome FR500
- 275/35/18 BFGoodrich g-Force T/A KDW 2
- ARP Wheel Studs
- Bullet Lug Nuts
- Rear -
- 18x10 Deep Dish Chrome FR500
- 295/35/18 BFGoodrich g-Force T/A KDW 2
- ARP Wheel Studs
- Bullet Lug Nuts
__________________
00 Mustang GT (4r70w)
Kenne Bell 1.7
376hp 404 tq
DarkSoul is offline   Reply With Quote
Old 01-06-2007, 05:59 PM   #47
Car_Ramrod
Send a message via AIM to Car_Ramrod
Vortech V2-SQ Supercharger
FRPP 42lb Injectors
SVT Focus Fuel Pump
NGK TR6 Spark Plugs
80mm MAF
BBK Ceramic Coated Longtube Headers
BBK Offroad H-Pipe
Bassani Catback
Autometer Cobalt Mechanical Boost Gauge
AEM Wideband Air/Fuel Ratio Gauge
Gauges mounted on Autometer Dual A-Pillar Pod
MGW Short Throw Shifter
Eibach Pro-Kit Lowering Springs
HP Performance Full Length Subframe Connectors
Centerforce Dual Friction Clutch
UPR Firewall Adjuster and Triple Hook Quadrant
SCT Xcal2 Dynotuned by Tony at HP-Performance
362 rwhp, 363 rwtq...but MAF got pegged at 5200...with new MAF and powerpipe should be capable of ~380-390 rwhp.
[IMG]local://upfiles/13981/59BCAE43A2524DF08392A5FD3B373CDA.jpg[/IMG]
__________________
Vortech V2-SQ, BBK LT Headers, O/R H-Pipe, Bassani Catback, Centerforce Dual Friction Clutch, MGW Shifter, Eibach Prokit Springs, and more...
New #s: 356 rwhp, 373 rwtq
Car_Ramrod is offline   Reply With Quote
Old 01-07-2007, 07:50 AM   #48
Flying Low
2000 Mustang Gt
K&N
Filter- C&L Inlet Pipe, Lightning 90mm MAF
Steeda UD Pullies
Steeda Timing Adjuster
Steeda U&L Aluminum Control Arms
Steeda Rear Sway Bar
Steeda 3 bolt CasterCamber Kit
Steeda Welded in Subframe Connectors
Steeda Clutch Cable & Adjuster
Hypertech 160 Degree Themostat
FR ShortieHeaders
FR Aluminum Drive Shaft &12 lbs Aluminum Flywheel
FR 3.73
Eaton Posi Diff
Canton Windage Tray
Meziere Electric Water Pump System
Pypes X pipe with Cats
Dynomax 2.5" Exhaust
Eibach Springs off a 2000 Saleen S281
Accufab 75MM TB, Plenum & Spacer
Granatelli O Ohm coils and NGK Platinum Spark Plugs
Diablo Tuner Chip to tie it all together, tuned for 91 octane fuel
Just Rescently Passed California Emissions
__________________
2000 Gt
3:73 G & EP Diff
All Steeda Suspension Stuff
Dynomax Exh, Pypes Hf XP & FR Shorties
273RWHP/302 fp torque & 22MPG Freeway
Lots of other great stuff.
CA SMOG
Flying Low is offline   Reply With Quote
Old 01-09-2007, 12:24 PM   #49
BamBam
2003 Mustang GT Convertible
Super Slow, but still fun (Except for the 147 in a 70)!
ProCharger Stage II P1SC w/ 3.6 (10#) Pulley
42# Injectors
70mm TB (Modified BBK)
MagnaFlow X w/ Cats
MagnaFlow Catback w/ MagnaPacks
Eibach Springs
DiabloSport Tuner (Preferred)
SCT SCal 2
Motive 3.90 Gears
03-04 Cobra dress and shoes
Baer Brakes
__________________
Procharger Stage II
DiabloSport (I like it better than my SCT)
MagnaFlow
Motive 3.90's
Eibach
Baer
http://www.BayouMustang.com/
BamBam is offline   Reply With Quote
Old 01-13-2007, 01:36 PM   #50
procs2v
2006 Dodge Magnum
My Garage
procs2v's Avatar
Vehicle: 09.5 Pontiac G8 GT
03 gt 5speed
mac cai
accufab 75mmtb
c&l plenum
pro 5.0 shifter
mac pro chamber xpipe
magnaflow cat back
4.10 gears
eibach springs
17inch dr's
venom n20 system 100shoot
tuned by JLP
397hp
12.13@110 1.63 60'
__________________
who cares how much hp you have or what car you own. Can you drive it?
In 1 year
2002 Z06
11.46@119 headers, cai, tune, dr
2006 MSRT8
12.65@110 cai, tune
2009.5 G8 GT
13.80@102 all stock 2.08 60'
procs2v is offline   Reply With Quote
17inchalumastar, 4, aluminum, arms, autometer, automotive, bell, drag, driveshaft, gt, kenne, mmr, onepiece, powerhouse, racing, tubular, weld, wheels, wideband
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
