Ford Mustang Forums - Ford Mustang Classifieds - MustangForums.com Photo Galleries - MustangForums.com Chat Room - Create an Account - Mustang News - Mustang TSB
Go Back   MustangForums.com > Ford Mustang Tech > 4.6L (1996-2004 Modular) Mustang > 4.6L General Discussion
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 12-27-2006, 06:21 PM   #11
Texas_Hot_Rods
Default RE: 12's in a 2v on a budget...vid up!
Quote:
ORIGINAL: Dan04COBRA
Quote:
ORIGINAL: SVTBill
Dude, that's awesome, but I can't have a DD with 4.10s, stupid auto.[:@]
Stop being such a burn-out queen and you can!
Is there any reason why 4.30's weren't used?
Is this the same car I saw featured in a magazine that had an Auto? Looks awful familiar and so does the mod list. Very nice
This was featured in MM&FF for the N/A 2v GT shoot out which is where the vid came from. It is a 5 speed car and is still kicking aroung FL as of now. Owner couldn't make the shootout and we needed one more car along with our 00 GT that ran so we took this one and I got to drive !! It was the only car there without long tubes, so you can bank that long tubes are the route to go.
As for 4.30's, it would have helped a ton, but we didn't have time to swap them before the trip ( 3 days from El Paso to New Jersey Atco Track). All in all, it was a great experience and opened alot of eyes to the fact that 2v's can run on a budget as there were no race cars allowed. Had to have interior, and be a street car for the shootout.
You can see the article in full here: (2nd one down, you'll see our THR rig in the background)
http://www.musclemustangfastfords.co...ts/index2.html
__________________
Brian Metzger
Texas Hot Rods
www.texashotrods.com
877-50-STANG
Texas_Hot_Rods is offline   Reply With Quote
Old 12-27-2006, 06:22 PM   #12
Quicktime_GT
Nice launch..
__________________
P1SC, 3 core, bolt ons
416/400
12.4@ 114- 2.1 60'
Video
Quicktime_GT is offline   Reply With Quote
Old 12-27-2006, 06:24 PM   #13
Texas_Hot_Rods
Quote:
ORIGINAL: svt99redcobra
the link doenst work for me
Here is another one with the VID: (click under the picture for vid- Quick Time)
http://www.musclemustangfastfords.co...ace%20%20.html
Brian
Texas Hot Rods
__________________
Brian Metzger
Texas Hot Rods
877-50-STANG
Old 12-27-2006, 06:29 PM   #14
Texas_Hot_Rods
Quote:
ORIGINAL: SVTBill
Were the cam's new? What kind were they? How much would it cost to have them installed at a shop?
EDIT: Have you guys had it dyno'd, if so, you have any numbers or videos or anything?
We sell cams new for $625 to the forum junkies. Usually $650 in our shop, but we always try to help. Installation would be $450 from us, you'll also need the head change kit $189 with all the gaskets/seals you will use. Cams will also require a tune which is why I listed the SCT ($379), which will net 260-280 rwhp with the mods listed from what we've tested.
It sure makes these GT's alot of fun when you see a vette or LS1 looking for an easy kill !
Brian
Texas Hot Rods
__________________
Brian Metzger
Texas Hot Rods
877-50-STANG
Old 12-28-2006, 03:25 AM   #15
CoolAid
__________________
'06 Pontiac GTO, LS2 400/400, 4L65E
CoolAid is offline   Reply With Quote
Old 12-28-2006, 03:31 AM   #16
Texas_Hot_Rods
Cams are new or at least were when they were installed. We dyno'd this one at 278 rwhp if I recall correctly. Like I said, it had 99k on the clock but still ripped. The CAI was a pieced together BBK kit. This car was built using as many deals on parts as you could hence the budget build part. I listed most of the parts in the list as new costs, but one could definitely save a few bucks if you shopped around or just collected parts and then installed them as you had them.
Even if you factor in the new stuff, it stills keep the cost down and makes it affordable for most daily drivers without going broke on a college or high school type budget. These cars are pretty neat with a little knowledge and some patience to putting the puzzle together.
__________________
Brian Metzger
Texas Hot Rods
877-50-STANG
Old 12-28-2006, 12:56 PM   #17
02StangGuy
could you run 12s with less? i just ordered tokico 5 way adjustanbe shocks ans struts and am getting lower controle arms. say i got a set of slicks...could i run like a 13.0?
__________________
256rwhp N/A
305tq N/A
360rwhp<100 shot
455tq<100 shot
02StangGuy is offline   Reply With Quote
Old 12-28-2006, 03:25 PM   #18
Texas_Hot_Rods
Quote:
ORIGINAL: 02StangGuy
Depending on your elevation, you could get into the 12's with slicks, the inductions items (TB, CAI, Plenum), gears, and a really good driver. The suspension will help a ton on the 60 ft's, but slicks will stick the stock to mild bolt on HP pretty easily. The shocks/struts & rear control arms will make a huge difference in the launch making for consistant runs and 60 fts. Look at the times on this one and you can see how this would be a killer bracket car. It runs the number every pass!
The cams are worth an easy 35 rwhp and most we tested usually make more hence the low to mid 12's in the vid for this one. This was also run at Atco (MMFF test track in NJ)and in Baytown (Houston, TX), so there wouldn't be much better air or track conditions as both are as close to sea level as it gets with great surfaces.
All in all to answer your question, shed as much dead weight as you can (ie: spare, jack, rear seat, passenger seat, stereo boxes, etc and witha slick and a few bolt ons you could hit the 12's. If you practice and pay attention to what you do that works, like shift points for instance or tire pressures, you can widdle the clocks down and get your timeslip.
Here are a couple more FREE mods you can do to get the most from your combo:
1) Air the front tires up, especially skinnies (just a bit over max pressure and don't forget to drop them for the ride home!)
2) Pull the passenger front headlight (2 clips and unplug the lights)
3) On slicks or sticky tires, do your burn out in 2nd after you roll through the water and keep the RPM's up around 5500. Then after they smoke, roll out and stage. NO DRY HOPS or clutch dumps before you launch. This will only take the bite out of the tires and heat up your clutch. This is the most common mistake you will see at the track where inexperienced drivers try to test the "stick" of the track. BAD IDEA, just do the burn out, stage the car, then do your thing!
4) Shed some weight, dump the spare, jack, iron, stereo boxes, back seats, and passenger seat. You can take this stuff out for the track,then stick it back in for the ride home. Less weight means quicker ET with the SAME HP.
5) Monitor your shift points and try different RPM's to see what your combo likes the best. Just because the redline is 6k, it doesn't mean that's were you shift. (I had a coupe that would vary from 12.20's 11.80's if I shifted it at different RPM's. It had a weak set of heads and small cam so it was done at 5500 and ran the best times shifting early. If I ran it to 6k on the shifts it would lose 3-4 tenths and a few MPH.)
6) Check your air filter and make sure it's clean.
There are probably a ton more items I could list, but this is the basics to make sure you get the most out of your track sessions. Good Luck
Brian
Texas Hot Rods
__________________
Brian Metzger
Texas Hot Rods
877-50-STANG
Old 12-28-2006, 11:40 PM   #19
mylongvictor
mylongvictor's Avatar
I wonder what mine will run....... Hmmmmmmmmmm
__________________
Procharger P-1SC 3 Core Intercooler
-477rwhp 460rwtq at 8psi (3.40 Pulley)
-8 Rib Pulley Conversion w/ 3.00 Pulley coming soon
-TKO 600 Swap
-Sanity on back order
(Old 3650 Tranny, Driveshaft, and PI heads.... For sale... PM me)
mylongvictor is offline   Reply With Quote
Old 12-29-2006, 03:40 AM   #20
Texas_Hot_Rods
Quote:
ORIGINAL: mylongvictor
easy mid 6's @ over 100.
in the 1/8!
It should be a solid 10 sec car with built motor and procharger if you dump some weight and hook up it up with some big n littles.
__________________
Brian Metzger
Texas Hot Rods
877-50-STANG
12, 12s, 2v, boltons, brian, dimensions, hot, m5300c, metzger, mustang, rods, run, sec, spring, texas
Featured Sponsors
Mustang Accessories
- Mustang Exhausts
- Mustang Mats
- Mustang Seat Covers
- Mustang Car Covers
- Mustang Head Lights
New Sponsors
Advertising Information - Contact Us - Ford Mustang Forums - Archive -
Top
© Internet Brands, Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
