wanting high hp...tranny? - MustangForums.com
Old 09-19-2007, 03:45 PM   #1
justang97
Default wanting high hp...tranny?
Well I am saving up for a KB kit for my car and the numbers are suppose to be 440 hp with 6psi, i have an upgraded driveshaft and flywheel...but what do you think about my transmission and that much hp? and if i need a new one which one should i get and will it bolt right in or what? also what kind of price am i looking at...thanks
justang97 is offline   Reply With Quote
Old 09-19-2007, 03:56 PM   #2
01GT4.6
01GT4.6's Avatar
Default RE: wanting high hp...tranny?
Quote:
ORIGINAL: justang97
if your tranny is in good shape and you don't feel like dropping the extra coin, stick with it. My T-45 has held upreally good to some good hp/tq numbers.
01GT4.6 is offline   Reply With Quote
Old 09-19-2007, 04:16 PM   #3
jman511115
I'd be more worried about your engine. Do you have the stock pistons, rods, and crank, or have you upgraded?
jman511115 is offline   Reply With Quote
Old 09-19-2007, 05:18 PM   #4
2000GT4.6
Quote:
ORIGINAL: 01GT4.6
Quote:
ORIGINAL: justang97
Its all about how you treat it. Hard launches and hard shifting will eventually destroy the transmission... taking it easy will make it last alot longer.
2000GT4.6 is offline   Reply With Quote
Old 09-19-2007, 06:10 PM   #5
justang97
o no, i am going to upgrade the bottom end...
Old 09-19-2007, 06:16 PM   #6
01GT4.6
01GT4.6's Avatar
Quote:
ORIGINAL: 2000GT4.6
Quote:
ORIGINAL: 01GT4.6
Quote:
ORIGINAL: justang97
I've always been told the launches don't affect it (since it's already in gear), it's the shifting you have to worry about. I don't know if it's true, but I have man, many hard launches (6k rpm dumps on slicks) but shift it easy and never had issues.
Shift Linkage Broke, Could Really Use Some Help CMcNam 4.6L V8 Technical Discussions 15 12-06-2015 02:28 PM
New Guy From Connecticut baron95 New Member Area 8 09-06-2015 10:24 PM
Did a few mods this summer... drfister 2005-2014 Mustangs 9 09-04-2015 08:47 AM
Torque Bias explained... ccwebb GT S197 General Discussion 2 08-11-2015 07:47 PM
Need Help Diagnosing Have Codes (Confused) djbigskrilla 2005-2014 Mustangs 13 08-11-2015 01:59 PM
440, driveshafts, hp, wwwhptrannycom
