New Steering Wheel...
Old 10-14-2007, 09:52 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Default RE: New Steering Wheel...
ORIGINAL: czwalga00gt
Is there a rooster on the steering wheel? Doesn't go with a sports car at all.... looks like something that should be in a bentley.... not really in a good way. The steering wheel isn't bad for a car like that with matching wood interior etc, but looks really out of place in the mustang.
Also did you check how much current runs through there? If you just got two 4.7 ohm resistors from radio shack odds are that thing is going to draw a ****load of current and burn the resistors.
Even at 5 volts 2.3 ohms its going to draw over 2amps which requiresatleasttwo 5watt resistors.
[/align][/align]That's Team VooDoo's logo, a prancing chicken--and I agree that it does not go well with a Mustang (which is a 2+2 GT coupe, not a sports car). It's what I had however...[/align][/align]Regarding the resistors, there is no significant current flow through the air bag sensing circuit; if there were the air bag would detonate... [/align][/align]The air bag controller passes a very small voltage (< 150 mV)from a high-impedance source (> 10k Ohms) through the squib (the detonator that sets the bag off and has a 2.3 Ohm resistance) to make sure it is in place and intact--the squib would detonate at anything over 8 V or so (assuming sufficient current capacity).[/align][/align]150 mV, across the paralled 4.7 Ohm resistors (=2.35 Ohms) = about 64 mA = about 100 mW; or about 1/5 the capacity of the paralleled 1/4W resistors (BTW, RS doesn't stock 4.7 Ohm resistors, I had to buy 50 from Newark Electronics--which means I've got 48 left if anyone needs any).[/align][/align]The resistors trick the controller into thinking the air bag is still there--they will of course fry if the controller deploys the non-existent air bag, however I suspect that would be the least of my problems at that point in time... [/align]
cliffyk is offline
Old 10-14-2007, 10:14 AM
03mustgt
03mustgt's Avatar
It's different, but it would look better if it was black instead of wood grain. I like the styling of the wheel, just wood grain has not been in mustangs in about 35 years.
03mustgt is offline
Old 10-14-2007, 07:48 PM
czwalga00gt
czwalga00gt's Avatar
ORIGINAL: cliffyk
Ok that makes sense, I was gonna say if they didnt attenuate the voltage down those resistors are gonna blow. Ususally they dont drop the voltage levels in the cars, everything is made to work on either 5v or 12v.
czwalga00gt is offline
Old 10-14-2007, 08:08 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
The air bags do WORK (as in BOOM) at 8.0V, but you can pass lower voltages through the squibs to test them--very low, current limited,voltages to make sure they don't go BOOM...[/align][/align]You can use a good DVM to measure the squib's resistance, however I was willing to take the factory manual's specs rather than check it myself...[/align]
cliffyk is offline
Old 10-14-2007, 08:10 PM
wgdt21
wgdt21's Avatar
its unique at least, and looks like a clean swap. I personally am not loving the style though.
wgdt21 is offline
Old 10-14-2007, 08:15 PM
Xemeth
Xemeth's Avatar
I think if the wood grain was black leather or something it would look OK. I think it looks too old school in a new style interior.
Xemeth is offline
Old 10-15-2007, 01:07 AM
FR500GT
FR500GT's Avatar
Im all for getting a new steering wheel. But why the wood grain. I personally would have gone with black suede of some sort. But to each his own, i guess.
Hey at least you dont have to worry about any other stang copying you
FR500GT is offline
Old 10-15-2007, 01:11 AM
dafizuck
dafizuck's Avatar
ORIGINAL: FR500GT
The man makes a very good point... nice swap but have to jump on the b wagon with everyone else.
dafizuck is offline
Old 10-15-2007, 11:04 AM
kecclest
kecclest's Avatar
+1... either paint it black, or sand it down and stain it darker.
kecclest is offline
Old 10-15-2007, 11:13 AM
TX97GT
TX97GT's Avatar
does anybody have a pic of a good looking replacement for my '97 with gray and black two tone interior? Mine is just looking a little worn on the top and bottom...
I might even look at a new oem one if they aren't really expensive, but it is ford... mucho $
TX97GT is offline
Quick Reply: New Steering Wheel...
