How much is my car worth.s/c fully built 2004
Well im thinking of sellin the stang but im not to sure on really what to ask for it?
It goes as followed
Car is a 2004 Dark Shadow Grey Manual 40th Anv 59k (but really has75 miles on it, keep reading you will understand)- has extended warrenty (not sure if all of it is voided) i have every recipt of all the matience and every aftermarket part put in it.
Engine
MMR900 Long block
fully forged engine with ported heads, arp studs, racing oil pump , 8 bolt crank, engine can handle a little bit over 900 hp - 6400$
Kenne Bell 1.7l Supercharger
6, 9, 12, 14lb pulleys, Kenne bell BAP -about 6000$
42lb injectors, 90mm mass air flow, jlt intake, bbk headers, slp catted x, slp lm2's, pro 5.0 shifter, Spec Stage 3 clutch, Fidanza lightend 8 blot flywheel,
The tranny was freshened 500 miles ago
New wheels and tires have less then 500 miles, they are deep dish anthricite fr500's wrapped with 315, and 275 in the frount BFG G-Force KD Dry Weather tires - about 2000$
New Brakes All around, power slot drilled rotors, ebc pads
The rear end is the only thing that hasnt been touched aside from a fluid change about 500 miles ago
Interior
Full Aftermarket stereo
Pioneer Primiere Headunit (one of the best) Infinity Speakers, powered by a rockford amp, rockford p2 10" sub, powered by a kicker amp.
Some misc billet things
interior color is the two tone tan leather, which is insanely clean, no stains burns or otherwise nasty things, when you open the door of this car you smell new car because it was constanly cleaned and the leather was always treated with lexol, you can eat off the carpets,
The car has ALWAYSSSS been garage kept never driven in rain or snow, no dents dings, or any other body imperfections
car has a mach 1 lip, grille delete, and billet antenna, mustang chrome insert letters
pics will come in a little bit.
It goes as followed
Engine
MMR900 Long block
Interior
RE: How much is my car worth.s/c fully built 2004
Since its an 04 its worth about $15k-$16k. You wont get any money for the aftermarket parts. But I would give you an extra $1000 for your work. But then I would subtract $2000 for the work I would have to do to get the extra weight of that stereo crap out of it. So around $15k.
sorry bro but all the adding you did for the price of things does lil to nuthing.most people would rather buy a bone stock car then one heavily modded like yours. not im not saying you wont get what you want. your just gonna have to stumble across the right person
