pro stars or light drag wheels
Old 01-13-2008, 09:17 PM
sstang
sstang's Avatar
Default RE: pro stars or light drag wheels
I'm probably going to get the Summit 5 spoke drag wheels since they are inexpensive. 15x8 in the back, 15x4 in the front.
sstang is offline
Old 01-13-2008, 10:18 PM
Xemeth
Xemeth's Avatar
How do skinnies handle for daily driving? I've heard they're not that great. That's why I wanted a set of regular sized street tires on the front, like a 205 or something. Maybe smaller. I have seen 185 on some old Buicks and Oldsmobiles. And then for the back I'd want to have two pairs, one 15x10 for fat *** street tires, and one 15x10 for drag tires.
What size sidewall would you guys recomend for a street tire? I was thinking 335/xx/15. I want to fill up the wheel well real well.
Oh, and can someone explain the numbering for drag radials? Like, what is 28x12? Is that overall tire height (including rim) by the width? I'm not sure if I totally understand.
Xemeth is offline
Old 01-13-2008, 10:24 PM
mylongvictor
mylongvictor's Avatar
ORIGINAL: Xemeth
I had that same question.... And it really didn't answer me as much as actually getting in a car and driving. W/ power steering and all, it friggin turns like butter. So smooth you forget that its a smaller tire and you have to compensate with braking distance and turning. I wouldn't drive as aggressive on the highway as you normally would, whipping through traffic and making last minute stops as you tailgate 5 feet from the person in front of you.
mylongvictor is offline
Old 01-13-2008, 10:27 PM
1fast 99gt
1fast 99gt's Avatar
ORIGINAL: ZW99GT
ORIGINAL: 1fast 99gt
draglights are lighter but prostars look better so weight or looks its your choice.
Are they really lighter?
yes i draglight wheel is very light.
1fast 99gt is offline
Old 01-13-2008, 10:28 PM
ZW99GT
ZW99GT's Avatar
I run 15x3.5 with 165R every single day. So do alot of my buddies. Obviously, you can't do 100mph around a banked turn, but you can drive normally just like everyone else with no problems.
and yes a 28x12 is a 28" diameter and 12" wide. You need something like a 26x10, and I don't think you need a 10" wide wheel.
ZW99GT is offline
Old 01-13-2008, 10:30 PM
mylongvictor
ORIGINAL: ZW99GT
One thing about the width of a Slick tire, the width it says isnt the width of the amount of rubber to the ground. Its the width of the sidewall. So like mine, 27x10.5.... Only about 8.5 to 9 inches are actually touching the ground.
Old 01-13-2008, 10:45 PM
Xemeth
Xemeth's Avatar
OK, well say I did have a 15x10 rim. What size tires should I use for them. Don't take power and need for them into consideration, just what size fits 10" rim the best?
Same question with a street tire? Would it be like 335/60/15 or something?
Xemeth is offline
Old 01-13-2008, 10:52 PM
mylongvictor
ORIGINAL: Xemeth
Well for a 15x10 rim, youshould be ablefit a slick 28x11.5 on them easy. You just gotta find out if your sidewall can take it, which I belive in your car it can.
I usually go by, rim width plus 2 1/2 for a slick, and1 1/2for a regular tire.
Old 01-13-2008, 11:02 PM
ZW99GT
ZW99GT's Avatar
ORIGINAL: mylongvictor
ORIGINAL: Xemeth
That's all good and true, but I'm trying to figure out what this guy is running to need a 28x11.50 ET DRAG. That tire ain't playing son. IMO, you are gonna need 500rwhp and more TQ to need that much tire.
ZW99GT is offline
Nick Oliver
10-17-2018 04:22 AM
11-10-2015 11:39 AM
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
Luke9222
09-04-2015 06:46 AM
amandahchase
09-03-2015 10:09 AM
Quick Reply: pro stars or light drag wheels
