Spark Plugs - Page 2 - MustangForums.com
Old 01-13-2008, 10:31 PM   #11
2000AZ5.0GT
2000AZ5.0GT's Avatar
Default RE: Spark Plugs
Quote:
ORIGINAL: tbirdscwd
Quote:
ORIGINAL: 1fast 99gt
vortech says to use oem plugs at oem gap this this true? i just got done putting in 42# injectors and oem spark plugs.
It really depends on your setup and how much pressure your running. If you are under 10psi, the stockers will probably be just fine, but I would still put the gap down to .040 max. One step colder is a good precaution especially for our stock internals. They pretty much won't hadle any detonation. I ran the OEM (non-platunum) when I was at 8psi for 6 months and never had any detonation issues.
But in his case running 14psi he definitely needs colder plugs and smaller gap.
I totally agree, and Im sure thats whats in there, or something similiar, but since I didn't build the car, I dont know what plugs were used and wanted to get an opinion before I went and screwed something up
2000AZ5.0GT is offline   Reply With Quote
what are the odds - Service Engine Soon light lincolnshibuya V6 (1994-2004) Mustangs 9 12-08-2015 05:37 PM
Bad cylinder? Dathan V6 (1994-2004) Mustangs 4 10-05-2015 06:52 AM
04 Mach 460 system, Installed Aftermarket HU, No Highs/Tweeters breaking Audio/Visual Electronics 5 10-02-2015 02:27 PM
Clear codes on '94 sn95 BOB ROME 5.0L (1979-1995) Mustang 2 09-28-2015 12:10 PM
Slight surge at 1500ish rpm lmurf60 4.6L (1996-2004 Modular) Mustang 1 09-24-2015 11:07 PM
14psi, 2000, 96, cobra, find, ford, gap, gt, location, mustang, plug, plugs, spacing, spark, sparks
