Last edit by: IB Advertising
Browse all: Specifications & General Maintenance
- Ford Mustang V6 and GT 1996 to 2014: How to Clean Your Engine
Step by step instructions for do-it-yourself repairs
How to wash your engine bay
#31
RE: How to wash your engine bay
I love cleaning the engine bay. I cover everything up then hose everything down with hot water to loosen things up then spray everything down with some kind of degreaser let it soak for 2 minutes or so then hose down again with the hot water. We can screw a garden hose onto our faucet in the sink down cellar. ran a hose through the wall etc. enough rambaling. Hot water does make things a bit easier, hard to see at times though
#32
RE: those of you who have new edge GTs and want to wash their engine bays
ORIGINAL: ZW99GT
That looks really good man! Thanks for the advice! Nothings worse than a dirty engine bay
#33
After I clean my engine bay i always blow it out and i go over all the plastic parts (ex. Radiator overflow air filter tube hoses valve covers ect...) with tire shine... Gives off a very good shine.
#34
&\\;nbsp\\;I cover up NOTHING!!! Def stay off the air filter. I always spray my engine running and Only when it&rsquo;s at running temp. Never cold. That is the biggest misconeption people have and why they have trouble with water. Spraying the battery is perfectly fine. Spraying the fuse box is fine as well, just cannot stay right on top of it. No alternator water. This is a must. Everything else has double insulated rubber protection from water and moisture. I leave the engine running with the hood just resting on the latch for about 1/2 hour so everything dries completely. Never spray a silicone tire type susbstance on your engine. It does nothing but catches dirt in every crack and crevice. Sure it looks good until you start driving down the road.<\\;br>\\;I&rsquo;ve been a professional detailer for 10 years. I own my own detail business. I have cleaned several thousands of engines and never not once had any troubles with running or driveability!!!<\\;br>\\;
#37
I have used gunk degreaser on mine, then i pressure wash it, BUT i didn't know that i was suppose to cover all that stuff. the good thing that i keep the gun away quite a bit for that reason not to damage anything. with this knoledge i will do it from now on ( i dont want to learn the hard way). One tip that i do and you guys might be interested is that for all the rubber hoses and stuff like that (EXCEPT BELT! it will make it squeek) i use a tire cleaner (found in autozone) sprayed onto a rag and clean to hose (dont apply directly to avoid over spray) and it will be like new! lol. NOTE: read the lable and make sure it says "wont atrack dusk/dirt." the one i use comes in a black bottle, it is water based and has silicone (i think) and it works great and makes the engine "plastics" look really nice and shiny. kinda like armor-all but shinyer!
#39
Clean bay man props got a car show coming up and my engine is filthy...i definitely need to wash the engine bay but im supercharged what extra precautions should i take? or should i just do my best with a rag?
