Go Back   MustangForums.com > Ford Mustang Tech > 4.6L (1996-2004 Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 05-18-2008, 02:35 AM   #1
00raging stang
Vehicle: 2002 gt
Default advancing spark usuing an sct tuner
does this do anything? i was told by bumping up the spark that it advances the timing it is set at 0 right now which is the way brenspees had it should i bump it up it goes up to 4 but i was told not to put it up all the way, would increasing the spark actually do anything for me? can it hurt the car in anyway?
__________________
2002 GT 5speed
-BBK CAI
-SLP LM1's
-STEEDA high flow catted X-pipe
-15%tint
-Terminator front bumper
-HID's
-FRPP 3.73 gears
- SCT X3
00raging stang is offline   Reply With Quote
Old 05-18-2008, 02:19 PM   #2
tim2002gt
2002 Ford Mustang
tim2002gt's Avatar
Vehicle: 2002 Mustang GT
Default RE: advancing spark usuing an sct tuner
If you advance your timing further, you will run the risk of detonation. Unless you are running a higher octane fuel.
__________________
11.54 @ 118.15
tim2002gt is offline   Reply With Quote
Old 05-18-2008, 04:07 PM   #3
avlon06
avlon06's Avatar
Vehicle: 2000 Mustang GT
SEARCH... been tons of threads on this subject latley
__________________
Exhaust clip
avlon06 is offline   Reply With Quote
Old 05-18-2008, 06:19 PM   #4
00raging stang
Vehicle: 2002 gt
really cause im on here more then once a day and i havent seen any, back to my question, anybody else? im running 93
__________________
2002 GT 5speed
-BBK CAI
-SLP LM1's
-15%tint
-HID's
-FRPP 3.73 gears
- SCT X3
Old 05-18-2008, 06:46 PM   #5
MoKo_04GT
try checking your OTHER/duplicate thread that you also posted in the tech section. that one has answers on it as well.
__________________
Tokico HP Blues - shocks & struts, ford racing "c" springs
LCA's are next...then im done for a while.
MoKo_04GT is offline   Reply With Quote
Old 05-18-2008, 06:49 PM   #6
kingofqueenz
i have the same question, i've read other threads but none of them fully explain it, they just post an article from a website with a dyno run. I advanced mine to the max on my diablo tuner and im running 93 octane and my car is running strong, but is there a risk by me doing this? should i back it down a notch to be safe? can i blow a spark plug or something?
kingofqueenz is offline   Reply With Quote
Old 05-18-2008, 06:52 PM   #7
MoKo_04GT
Quote:
ORIGINAL: MoKo_04GT
give me a minute and i will use the search feature for you, to find my answer to this from the day before yesterday. this way i can just cut and paste the answer instead of writing it all again.
__________________
Old 05-18-2008, 06:52 PM   #8
MoKo_04GT
Quote:
ORIGINAL: MoKo_04GT
Quote:
ORIGINAL: MoKo_04GT
alright....here is the deal. you can bump the timing up as high as you want. the higher you put it, the more horsepower you will get out of your tuner. what you want to make sure of tho, is that you dont hear your engine knocking/pinging/or making any other strange noises that it DID NOT make before the adjustments. so if you hear it ping...then back off the timing by one degree and try it again. if it still pings, then keep backing off 1 degree untill it doesnt, then you will be at your peak point.
now something else you HAVE TO take into considertaion when doing this. the higher you put your timing, the higher your octane of gas needs to be.
your a/f ratio, i wouldnt mess with it too much, b/c you dont have any way of knowing what it is at right now. thats more to be messed with when you get a dyno tune.
here is how i run mine....brenspeed 93 octane tune....i fill up on 93 and add 2 gallons of 101 ocatane (the sell both at the shell i go to), then on the tuner i have mine turned as high as it will go on global spark, and as high as it will go all thru out the rpm range, and my car does not knock or ping what-so-ever, and runs like a bat out of hell.
__________________
Old 05-18-2008, 06:53 PM   #9
MoKo_04GT
Quote:
ORIGINAL: MoKo_04GT
Quote:
ORIGINAL: MoKo_04GT
Quote:
ORIGINAL: avlon06
anyone done this with a diablo tuner? just dont want to fugg things up
SCT....Diablo....Sniper....steeda timing adjuster, etc....
it doesnt matter what the brand is, its all done the same way....spark advance, is spark advance.
the whole key is just making sure you dont hear any NEW noises AFTER you have made the adjustments.... ie: knocking, pinging, any other ab-normal noises. like stated earlier, if you hear it ping, back off one degree, and then try again. if it still pings, keep backing off 1 degree untill there is no knock/ping.
like i said with mine its advanced all the way up, on both global settings and thru out the rpm band....now i HAVE NOT tried the timing all the way up on just strait 93. it might ping, who knows. like i said i usually add 2-3gallons of 101 octane to my 93, which allows me to buimp my timing even higher (than brents performance tune already has), which makes more horsepower...and i have never heard her ping once.
__________________
Old 05-18-2008, 07:55 PM   #10
kingofqueenz
ok, my exhaust is too loud to hear detonation so i don't know if it is. I dont hear any pinging, i have it at the max spark and im running 93, i don't know why your wasting your money putting 2 gallons of 101 if the tune is for 93. If you have the steeda timing adjuster then i could understand y your using 101 octane. What type of problems can arise from pinging and detonation?
101, advance, brenspeed, changing, degree, global, gt, max, mustang, sct, setting, settings, spark, timing, tuner, tuners, x3
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
