Serious clutch problem! Need help
When the car sits overnight, I start it up and can't get it to go in gear. I have to pump the clutch a couple times to get it to shift into gear without much effort. The second i lift my foot off the clutch it engages. After you drive a little the engagement point is up higher on the pedal.
The steeda quadrant has 2 hooks and i have the stock cable on the first hook. I have the firewall adjuster turned out far enough that it is hard to turn now.
Is it POSSIBLE to get a longer cable to hook onto the second hook to give the clutch more throw and engage the clutch a little further????? The stock cable will not hook the second hook without me prying the fork back far. The steeda adjustable cable is the same way and will only catch a few threads. Any manufacturers make longer cables??Is this my problem.
even though the stock cable looks good and i cleaned it real well, could it be stretched causing this problem?? Is this a tell tale sign. If so i'll try for the 1000th time to put in the adjustable cable which never seems to work!
Yeah i like the stock design, however with it being stretched so badly I put the steeda adjustable cable in. It is much smoother. However, still very low and have to pump the clutch a little. I put anti seize on the firewall adjuster and it made it so much easier to turn. I can drive the car at the point it's at but may just turn it out a little further in a couple days. I heard the king cobra's are notorious for being right off the floor clutches. The disc is thinner and the marcel spring in the clutch disc has more room to move.
<snip>Is it POSSIBLE to get a longer cable to hook onto the second hook to give the clutch more throw and engage the clutch a little further????? The stock cable will not hook the second hook without me prying the fork back far. The steeda adjustable cable is the same way and will only catch a few threads. Any manufacturers make longer cables??Is this my problem.
mungodrums
10-07-2015 04:01 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-03-2015 07:14 PM
