RATTLE is driving me nuts.
Old 09-27-2008, 09:23 PM
mdubbs
mdubbs's Avatar
Default RATTLE is driving me nuts.
The end of the clutch cable is vibrating on the steeda quadrant. It is just loose enough to rattle ever so often. I just installed a new spec clutch and do not want to tighten the firewall adjuster anymore. Right now i got a little freeplay at the top of the pedal (1/2"- 3/4"). I can pull the cable away from the firewall adjuster about 1/8" and the throwout bearing is just kissing the pressure plate fingers. Today i put heater hose inside the firewall adjuster so that the cable does not rattle inside the adjuster.
Any ideas what i can put on the end of the cable to stop the rattle.
Also is it normal for a clutch pedal to get firmer as the clutch begins to wear. I got 240 miles on it and the chatter is going away and the clutch pedal is defientley getting firmer.
mdubbs is offline
Nick Oliver
10-17-2018 04:22 AM
bjdutch2005
03-24-2017 03:38 AM
StalkerGT
09-25-2015 02:41 PM
robjh22
Suspension
09-08-2015 12:47 PM
tmdm
09-04-2015 06:45 PM
Quick Reply: RATTLE is driving me nuts.
